Page 1 of 4 1234 LastLast
Results 1 to 15 of 48
Thread: Recaro seats?
    vcaddy06's Avatar
    vcaddy06 is offline Cadillac Owners Fanatic
    Automobile(s): '06 Black Raven CTS-V
    Sep 2009
    Palm Beach County, FL
    168
    Recaro seats?
    Has anyone here thought about or already installed Recaro seats into their V? The factory black leather/suede seats in my '06 V weren't in that great of condition when I bought the car and only gotten worse. Was wondering rif anyone knew if these would fit and utilize factory frame and heat option.
    https://www.recaro-automotive.com/us.../style-xl.html
    BradCTSV is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac 2005 CTS-V
    May 2007
    114
    Re: Recaro seats?
    I'm planning to install Recaro Speed seats next week. Since stock seatbelts are mounted into the seat, I ordered Wesco retrofit 3-pt belts...hoping there are mounting points already in the B-pillar and if not will weld in mounting points. Will also try to move the heat/airbag sensors from the stock seat to Recaro. Finally, to close the loop for the driver/passenger airbag you have to put an inline resistor....I'm hoping to get one from airbagsystems.com next week.
    Thanks to others who have provided a lot of info on this mod....I will post pics when this is done.
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,463
    Re: Recaro seats?
    Please post as many pics and technical details as possible. There have been a number of discussions about this, but the 3-point belts in particular have only been speculated about - I don't think I've ever seen any pics.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  5. #4
    Isaacs is offline Cadillac Owners Member
    Automobile(s): '06 CTS-V
    Jun 2012
    30
    42
    Re: Recaro seats?
    I pulled off my B pillar panel hoping for a factory mounting option....no such luck. Idk about welding in a mount. The sheetmetal is a bit thin IMO.
  6. #5
    vcaddy06's Avatar
    Sep 2009
    168
    Quote Originally Posted by Isaacs
    D**n. That sucks. Anyone know where or how I could get my hands on a newer set of front seats? Or maybe should just have them reupholstered.
  7. #6
    May 2007
    114
    Re: Recaro seats?
    Thanks, good to see this. I will have to check with some experts to see what can be done. The first thing that comes to mind is to insert threaded steel plate behind the existing slotted sheet metal.
  8. #7
    ctsv247 is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Stealth Gray V
    Feb 2009
    Greenville sc
    45
    992
    Re: Recaro seats?
    Quote Originally Posted by BradCTSV View Post
    I agree. Mounting the belts shouldn't be to difficult because this is a nice flat clean surface to work with.
    Which type of wesco belts were you looking at and would it make sense to try and mount some kind of GM pillar mounted, retractable belt instead so that you could use the existing buckle assembly?
  9. #8
    May 2007
    114
    Re: Recaro seats?
    Here are the Wesco 3 pt. belts I ordered which are designed to mount on a b-pillar. They are retractable and I think they will work just fine. The biggest issue is figuring out all the airbag and seatbelt sensors. Car goes into the shop next Tues and I'm hopeful we can figure it all out. I've also been talking to some companies that specialize in airbags.
    Link to 3pt seatbelts:
    http://wescoperformance.stores.yahoo.net/resebe.html
  10. #9
    May 2007
    114
    Re: Recaro seats?
    Attached is a picture of my recaro seat project in progress. The 3 point belts are mounted in the B-pillar and almost done...luckily the factory had a threaded point to mount the seat belt retractor and a plate will be mounted for the shoulder point. We are still working on the airbag and passenger pressure sensor but using the schematic we will work this out.
  11. #10
    AAIIIC's Avatar
    Aug 2007
    6,463
    Re: Recaro seats?
    More peek-shuhs, pleez!!!
  12. #11
    mberisha's Avatar
    mberisha is offline Cadillac Owners Connoisseur
    Automobile(s): '11 Black Escalade AWD & '06 Black CTS-V
    Aug 2009
    Aviano, Italy
    38
    1,898
    Re: Recaro seats?
    Very nice....those seats looks perfect in there!
  13. #12
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    Re: Recaro seats?
    Well done!
  14. #13
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    I'm squidging right now!
    But why is this in appearance?
  15. #14
    May 2007
    114
    Re: Recaro seats?
    Thanks for the feedback. Iwill post a bunch of pics in the next few days...busy getting the bracket fabbed for the passenger side and working on the airbag sensors.
  16. #15
    UnsafeAtAnySpd's Avatar
    UnsafeAtAnySpd is offline Cadillac Owners Connoisseur
    Automobile(s): '04 CTS-V, '07 SRT8 Jeep, '86 Fiero
    Aug 2007
    Arlington, VA
    31
    1,647
    Re: Recaro seats?
    Keep us updated. I need some airbag sensors to get rid of the warning and light every time I get in my car.
  • You may not post replies
