One more time....Plus size wheels/tires
Page 1 of 3 123 LastLast
Results 1 to 15 of 31
2004-2007 Cadillac CTS-V Appearance Mods Discussion, One more time....Plus size wheels/tires in Cadillac CTS-V Series Forum - 2004 - 2007; OK...let's go around again....<insert dead horse here> Who has 19s? Who has shoved 255s up front, and 275 in rear? ...
    urbanski is offline Cadillac Owners 10000+ Posts
    Automobile(s): 05 CTS-V
    Mar 2003
    San 'tone, TX
    23,163
    Who has 19s?
    Who has shoved 255s up front, and 275 in rear? Issues such as control arm rubbing?
    Will 255s fit onto a 9" rim, will 275 fit on a 9.5" rim, with no bad effects on handling?
    I just was checking out these wheels over at another "CF"
    http://forums.corvetteforum.com/show....php?t=1035106
    and oh man are they sweet...but I want 19s and I want to pack as much rubber under her as I can
    oh and Shane your PM box is full again LOL
    thanks!!!
    Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
    Dreamin is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 ATS-V
    Feb 2004
    Calif.
    2,261
    Re: One more time....Plus size wheels/tires
    Did you give up on John??
    You need to keep the front and rear diameter the same... as close to the same as possible. 255 and 275 wont be the same... run 245/40/19 and 275/35/19 rear or 265/40/19 all the way around.
    See post #13:http://www.cadillacforums.com/forums...ad.php?t=32823
    The V PCM does not like difference in front-to-rear diameters!!
    Handling will be fine with 9" front and 9.5" rear... even 9" front and 10" rear... yes, you'll have a little more understeer... but this can be corrected by applying a little more power... And you'll be able to power out of corners a lot more confidently than with the stock 8.5" rear.
    HMO...
    ssmith100 is offline Cadillac Owners Connoisseur
    Feb 2004
    Conroe, Texas
    48
    1,394
    Urb,
    Emptied bro. Still not sure if the 9" front is going to fit without rubbing. It will be close. My wheels are coming off this weekend to go to John for chroming. Looking at my new powdercoated rotors now on the floor. They look good. I may stick with the 8.5" on the front. Going to talk to John later. I'll keep you updated. Brake rotors going on tommorrow and I'll post pics.
    Shane
    lasstss's Avatar
    lasstss is offline Cadillac Owners Connoisseur
    Dec 2003
    Ellicott City
    2,873
    Quote Originally Posted by ssmith100
    Urb,
    Shane
    Looking at the front tires on a lift, the stockers are extreemly close to the upper spindle arm.1/4" gap at most. Any more width in a wheel has to go to the outside and that is a different issue.
    Mar 2003
    San 'tone, TX
    23,163
    Quote Originally Posted by lasstss
    Thanks guys as usual
    lasstss, I wonder if the width can be forced to go outside with spacers/offsets, etc. Trouble is, I'll be doing this all over the internet, hard to real life test fit stuff. I just may stick with 8.5" and 245.
    Dreamin, I dunno...I am torn...I fell in LOVE with those HRE C20s, and John still has no clear date on when the new finish process will be done. Last I called he changed the finish from "nickel chrome" to "black"....I really don't want black, as much as I don't want just bare polished Aluminum.
    ---And thanks for the info on sizes. I'll do 245/40 and 275/35. Just how would 265 fit up front? And I don't mind a little understeer with staggered sizes. I may welcome it a bit.
    Shane....yeah, find out what's going on OK? What's that elusive "new finish" going to be and WHEN???
    CTS-VPaco's Avatar
    CTS-VPaco is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Raven/Ebony CTS-V
    Mar 2005
    Moore, OK
    42
    344
    I spent some time with a friend of mine who works at Firestone and we checked tire sizes for 19x8.5" and 19x10" rims. We came up with 245/35's and 275/30's were the same size but approximately 1" smaller in diameter that stock wheels 'n tires.
    I may go with a 19x9" up front and I'm not sure if the 245 will fit properly. The only person I know with extensive tire knowledge is at the Supra meet in Houston, TX right now. Anyone have any feedback on this?
    Feb 2004
    Calif.
    2,261
    ...Very carefully...
    Pic attached of the mallett wheels 9" in front w/265s. 1/4" inboard, 1/4" outboard... making it flush with the edge of the fender.
    http://www.cadillacforums.com/forums...ad.php?t=29712
    Shane just tell John... "Mallett can get 9" wheels to fit?!" AND you dont want them to stick past the fender... Mallett's wheels to not stick out!
    Goto: http://www.mallettcars.com/ and click "Available NOW: CTS-V wheels in 19x9!" for more pics.
    Feb 2004
    Calif.
    2,261
    A little bit 'duller' than this...
    and WHEN???
    ...it may be a while now... Racing season is about to start and John is going to get sucked up supporting his teams...
    Feb 2004
    Calif.
    2,261
    Firestone's computer is on the fritz or you had the option turned on.
    245/40/19 and 275/35/19 are IDENTICAL to stock diameter...
    And 245's will be on a 9" wheel... look at the tire's spec sheet (or goto Tirerack)... the "Acceptable Rim Range" is: 8" to 9.5"
    Feb 2004
    Calif.
    2,261
    I've got a 1/4" spacer at home... i'll throw it up front and post some pics (probably next weekend).
    Shane: Do your rear wheels stick past the fender??
    CTS-VPaco's Avatar
    Mar 2005
    Moore, OK
    42
    344
    Quote Originally Posted by Dreamin
    Thanks for the feedback and siting your source! :coolgleam
    Mar 2003
    San 'tone, TX
    23,163
    thanks guys...
    I don't like those Mallett wheels.
    And Dreamin, if John is going to be busy, I'll just order HREs.
    CTS-VPaco's Avatar
    Mar 2005
    Moore, OK
    42
    344
    OK, after a li'l bit of free time (Godamn customers think they come before me and this important information regarding plus-sizing my rims!) I did the math and here is what I have...
    Stock 245/45/18's - 110.25mm of sidewall = 4.341" (Rounded to the nearest 1000th) = 22.341" of wheel diameter.
    245/40/19's - 98mm of sidewall = 3.858" = 22.858" of wheel diameter.
    275/35/19's - 96.25mm of sidewall = 3.789" = 22.789" of wheel diamter.
    So, what I want to know, is this difference negligible or will it cause trouble with the car's electronics? It is approximately a half-inch of difference between stock rolling diameter and the new set of 19's. Help?
  16. #14
    odysseus's Avatar
    odysseus is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS Manual Trans., '93 STS
    May 2004
    Yorktown, VA
    54
    3,035
    Quote Originally Posted by CTS-VPaco
    The theory is correct, but the math isn't quite right, if you're calculating wheel (with tire) diameters. You don't need to subtract one sidewall width. They should be somewhere in the 26" to 27" range.
    Basically, 245mm wide divided by 25.4mm/inch (to convert to english units) times 45% (sidewall to width ratio) times two sidewalls widths (top and bottom of rim) plus 18 inch rim diameter = 26.8"
  17. #15
    Mar 2003
    San 'tone, TX
    23,163
    just use this guys
    http://www.1010tires.com/tiresizecalculator.asp
    Oh, and I just ordered the HRE C20s (sorry John).
    19x9F, 19x9.5R, 245/40F, 275/35R
    YAY
  18. Remove Advertisements
