Replacement lenses or aftermarket units for HID Gen I V
Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By mackey
  • 1 Post By aantalis
2004-2007 Cadillac CTS-V Appearance Mods Discussion, Replacement lenses or aftermarket units for HID Gen I V in Cadillac CTS-V Series Forum - 2004 - 2007; Every listing I find for an aftermarket set of headlights says clearly that they are not compatible with HID systems. ...
    throttljock is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Aug 2012
    Ann Arbor
    24
    Every listing I find for an aftermarket set of headlights says clearly that they are not compatible with HID systems. Does anyone make an aftermarket HID headlight? Mine work fine, but its a 2004 and they are starting to show their age. I would be happy with a new set of lenses only to swap the guts of the lights back into, but I can't find just the housings either... What's the answer?
    Andringa is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Blk/Blk
    Nov 2009
    Wisconsin
    33
    785
    Re: Replacement lenses or aftermarket units for HID Gen I V
    Your only option for a brand new Headlight designed for HID is a new OEM unit at $900+.
    Some people buy the aftermarket halogen headlights and put HID conversion kits in.
    Personally if they work fine and are just getting cloudy, I'd sand them, polish them and then spray them with a clear to keep them looking good.
    I haven't asked around, but you could probably find a local body shop that could help you out.
    mackey is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V Black
    Sep 2012
    172
    cheapest solution is to correct them either using a "restoration" kit or your favorite correction method then add opti-lens to coat it.
    shadybx7 likes this.
    shadybx7's Avatar
    shadybx7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Platinum CTS V-Headers+3in pipes
    Apr 2008
    3,014
    http://ls1tech.com/forums/cadillac-c...eadlights.html
    current discussion/\
    did the restore kit twice.. still hazing probably going to go after market
    aantalis's Avatar
    aantalis is offline Cadillac Owners Member
    Automobile(s): 2005 CTS V Stealth Grey 2008 Hot Lava
    Dec 2007
    Indiana
    41
    See this thread http://www.cadillacforums.com/forums...eadlights.html
    I did the aftermarket halos with Chinese HIDs and 1 yr later am very pleased. I was worried the light pattern would be inferior but it's as good as original. I wouldn't go too blue unless that's what you like. This issue is connecting four wires and how best to do it. Soldering is best but harder to do the car side.
  8. Remove Advertisements
