Before & After EZLip
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 25
Like Tree7Likes
2004-2007 Cadillac CTS-V Appearance Mods Discussion, Before & After EZLip in Cadillac CTS-V Series Forum - 2004 - 2007; First, a little background: When I bought my V, it was missing the lower air deflector and belly shield. I ...
    Manseeno is offline Cadillac Owners Member
    Automobile(s): '04 CTS-V (No Moonroof)
    Apr 2012
    Bay Area, CA
    37
    55
    First, a little background: When I bought my V, it was missing the lower air deflector and belly shield. I really wanted to make it right using correct parts, I even special ordered the belly shield from the dealer....but I found that the holes were torn away from underneath the front bumper so the front of it will not attach securely (I haven't give up yet though, might try zip ties instead of the PITA push pins). So, I'm not ready to replace an otherwise perfectly fine front bumper, so I thought I'd try an inexpensive option for the other piece my V was missing. Here's before and after attached:image.jpgimage.jpg
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,217
    Re: Before & After EZLip
    What are we supposed to be looking at? Perhaps you could provide some description to go along with the poorly illuminated photos.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    He did the $10 Home Depot mod, but paid $30 for it.
    pirategrad87 and pirategrad87 like this.
    Apr 2012
    Bay Area, CA
    37
    55
    Sorry for the poor pics, I was trying to show how this looks just in case anyone else finds themselves in the same situation.
    The first pic shows my lower bumper missing the lower air deflector (the black rubber piece that's supposed to be there is missing, and the mounting grooves/slots are damaged & hanging).
    The second pic shows the garage door seal installed where the factory lower air deflector would normally go. Again, I did this because the slots that would hold the missing factory piece in place was missing (like it bad been torn out).
    And yes, this is the infamous garage door seal lip....I did try using the stuff from Lowes first, but the double-sided tape would not adhere....so yes, I paid $30 for the ~$10 mod, lol but to me it was better than spending $100 for another part from the dealer that may not be able to stay attached.
    AAIIIC's Avatar
    Aug 2007
    6,217
    I don't understand what I'm seeing in the first picture. My bumper doesn't have a row of bumps sticking down like that.
    Quote Originally Posted by FuzzyLogic View Post
    Heavens! He'll probably have to take out a loan to make up that massive difference.
    Apr 2012
    Bay Area, CA
    37
    55
    [QUOTE=AAIIIC;3191720]I don't understand what I'm seeing in the first picture. My bumper doesn't have a row of bumps sticking down like that.
    That's because your V very likely still has the correct factory lower air deflector; if you ever damaged it to the point it had to be removed, then your lower front bumper will look like my "before" pic.
    AAIIIC's Avatar
    Aug 2007
    6,217
    I've had the front end disassembled twice. Mine doesn't look like that, hence my statement.
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    At some point some shop or dealer didn't replace some of the pushpins under my '09. At VIR, the undertray broke loose and was flapping away, creating massive turbulence. That caused the base of my hood(at the windshield) to flap about 3/4". I could maybe budge it 1/4" by hand.
    Got underneath and ziptied up what I could and used pushpins in a couple other spots and went back out, hitting 150mph...
    jaygone7's Avatar
    jaygone7 is offline Cadillac Owners Member
    Automobile(s): 04 CTS-V1 ls6
    Jul 2012
    27
    38
    DangeRuss and DangeRuss like this.
    ONEBADCADDIE's Avatar
    ONEBADCADDIE is offline Cadillac Owners Member
    Oct 2012
    Tampa FL
    43
    Quote Originally Posted by jaygone7 View Post
    How did you install yours? I like how it sits closer to the front and is more of a lip. Since I don't have my oem I want to do this.
    Mar 2011
    2,045
    Don't bother. It looks terrible and doesn't function under wind resistance because it's too soft. You might be able to build up the area behind it with a strip of metal, but that'll be ruined the moment you hit a bad bump and scrape the front end.
    jaygone7's Avatar
    Jul 2012
    27
    38
    3m double sided tape and tap screws with big washers.
    Been 9 months on and no issues and I had bottom out a lot of times!
    Since its flexible walks right threw anything
    RCVW's Avatar
    RCVW is offline Cadillac Owners Fanatic
    Automobile(s): "Angel Dust" 2004 White Diamond CTS 3.6L-V
    Feb 2011
    Queens, NYC
    28
    390
    Ive done similar to my front bumper....nothing but compliments from folks. Wish I could fiberglass or carbon it over actually...
  16. #14
    xbladr is offline Cadillac Owners Fanatic
    Dec 2008
    377
    is that matte white?
    RCVW and RCVW like this.
  17. #15
    Oct 2012
    Tampa FL
    43
    I like the white. On a mission at the moment of painting or wrapping mine matte white
  18. Remove Advertisements
