Wheel Offset question
Results 1 to 5 of 5
2004-2007 Cadillac CTS-V Appearance Mods Discussion, Wheel Offset question in Cadillac CTS-V Series Forum - 2004 - 2007; I've been looking for a winter wheel option and I found some new alloy wheels that are the same rim ...
    jeph054 is offline Cadillac Owners Fanatic
    Mar 2012
    Rochester Hills, MI
    237
    I've been looking for a winter wheel option and I found some new alloy wheels that are the same rim size, width and bolt pattern. The problem is the OEM offset is +42mm and this wheel is +51mm. Can anyone confirm that this difference in offset is insignificant? It seems to me that it souldn't make a big difference.
    I8URSVT is offline Cadillac Owners Member
    Automobile(s): '07 CTS-V
    Jul 2011
    Fairfax Station, VA
    29
    56
    Re: Wheel Offset question
    10mm spacer and they will sit as if they were stock.
    CoSteve is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Sep 2012
    Littleton, CO
    71
    what did you find?
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,540
    Quote Originally Posted by jeph054 View Post
    Go look at your car. Will everything clear if the wheel/tire is moved inboard 9mm? I think you're going to be getting awfully close to the knuckle.
    Quote Originally Posted by I8URSVT View Post
    Once he installs longer studs, of course.
    Quote Originally Posted by CoSteve View Post
    what did you find?
    Yeah, what he said!
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    Mar 2012
    Rochester Hills, MI
    237
    You guys all are right. I would need the spacer and longer studs...Eff that! I found a set of Stocker wheels with a little road rash and the TPMS for 500 total. I lucked out. So now I will slap a set of LM-60's on there and I will be good to go for the next 4-5 years.
  8. Remove Advertisements
