Front Lip and Headlight Scratches.
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
2004-2007 Cadillac CTS-V Appearance Mods Discussion, Front Lip and Headlight Scratches. in Cadillac CTS-V Series Forum - 2004 - 2007; My front lip seems to be falling off, I pushed the rubber back in place but whatever clips or screws ...
    xxxcrown Guest
    My front lip seems to be falling off, I pushed the rubber back in place but whatever clips or screws were holding it in are gone now. What kind of clips.screws are used to hold in the lip?
    Also, on the top of my headlights where the headlight is flush with the hood, I have scratches from what appear to be rock chips? I don't know if this is common or what but the V's I looked at has similar damage on the headlights. Any idea how to get the scratches out?
    carlson_mn is offline Cadillac Owners Enthusiast
    Automobile(s): Platinum 06 CTS-V, kooks, magnaflow
    Jul 2012
    MN
    34
    636
    Re: Front Lip and Headlight Scratches.
    Mine and the others I have seen also have the damage on top of the headlights, but I think it is sun damage that gives them that "worn leather" look.
    xxxcrown Guest
    I am taking about scratches on the top lens area.
    Jul 2012
    MN
    34
    636
    yeah that is also what I meant. Every V1 I have seen has looked the same, always real beat up and spider web looking on the very top where it really catches the sunlight, looks like the top layer of plastic starts to have micro cracks and splinters all over.
    Teamsorad is offline Cadillac Owners Fanatic
    Jun 2012
    35
    177
    they have a wet sand kit for the headlights. mine were really faded on the top, almost a foggy look. I had a friend do it for me, I can get the info if you like. Don't have a before pic but can post the after if that would help
    you can post a pic of your headlights take make sure we are talking about the same thing
    xxxcrown Guest
    Quote Originally Posted by Teamsorad View Post
    Mine looks more like what carlson was talking about, like if the plastic is splintered on top. The only thing I could think of is that the slightest contact with pebbles and rocks cause it to get scratched.
    vettepoweraddict's Avatar
    vettepoweraddict is offline Cadillac Owners Member
    Automobile(s): 05 v Black Raven
    Sep 2007
    Wisconsin
    57
    27
    Trust me, its ultravoilet sun damage. The plastic along the gray edging on the top and sides starts to "crack" First you will have a couple then it will turn into dozens. I was going to paint my lenses to cover up the cracks but a thread on this site showed the 3M headlight resoration kit. It a sanding pad that fits on your drill and wetsand and polishes the lenses. Works perfect. I did mine and they now look new. BTW the gray is on the inside of the lenses. Also I highly recomend taping the painted fender edges off will mutiple layes of painter tape so as not to sand any painted surface.
    It took me about 2 hours start to finish highly recomend
    The bottom rubber "LIP" on the bottom of the bumper is held on with those plastic push rivets. They are a little bigger than the ones along the inner fender well to fender infront of the wheels
    kerberos's Avatar
    kerberos is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Jul 2007
    53
    You can get the bumper rivets at any auto parts store. $3-4 a package for 4-6 rivets. The lip uses longer and more slender pins than the fender trim and bumper pins.
    Like everyone else said, try wet sanding the headlights. I just spent some time with mine and it was worth it. You have to put some time into it, buts its worth it. Spend extra time on the buffing, it helps. I didn't like the polish that came in the headlight kits, was made for plastic, but didn's seem to do a good job on the clear and shine. I used a combination of the plastic wax and deep crystal wax. I was surprised by the outcome. Ended up doing my wives car and my truck too. Can't wait to do the tails on those two.
    odla's Avatar
    odla is online now Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,365
    for the lights i used mothers headlight restoration kit. They were pretty bad the first time. Now i do a full sand and wax once a year. Ill post pics when i get the picture off my phone.
    thefulmonty_07 is offline Cadillac Owners Fanatic
    Automobile(s): 05 CTS-V
    Jul 2010
    Sierra Vista, Arizona
    117
    Yea just pull a few out and take it with you to Lowes or Home Depot they'll have them there.
    odla's Avatar
    Nov 2006
    miami ,Fl
    2,365
    Here are some pics.
    6 SPEED Z is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Red Line CTS-V
    Dec 2008
    Dover, Delaware
    278
    I took it one further and covered the headlights with a 3m "clear bra" designed for the headlights and use a low dollar vinyl black overlay made out of a roll of vinyl striping from Pep Boys for the top of the headlight.
    stepchild21's Avatar
    stepchild21 is offline Cadillac Owners Fanatic
    Mar 2012
    156
    Those headlights turned out great. Huge difference
  16. #14
    JD03Cobra's Avatar
    JD03Cobra is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 Thunder Gray 6MT
    Mar 2008
    Michigan
    44
    2,122
    I used the Mothers kit and couldn't get the headlights to buff out real clear. Seem to show some swirls and I was buffing like a mofo with the drill....kinda sucked.
  17. #15
    Dec 2008
    Dover, Delaware
    278
    Quote Originally Posted by JD03Cobra View Post
    I broke out the "heavy artillery" and used the full size paint buffer with a hard cut pad and the 3m buffing compound, came out great.
  18. Remove Advertisements
