Cts v dual halo aftermarket headlights. - Page 10
Page 10 of 14 FirstFirst 1234567891011121314 LastLast
Results 136 to 150 of 199
Like Tree19Likes
2004-2007 Cadillac CTS-V Appearance Mods Discussion, Cts v dual halo aftermarket headlights. in Cadillac CTS-V Series Forum - 2004 - 2007; That is IF the Cts uses smaller gauge wires. Could be simply the fact that the headlights are aftermarket and ...
  1. #136
    stepchild21's Avatar
    stepchild21 is offline Cadillac Owners Fanatic
    Mar 2012
    156
    That is IF the Cts uses smaller gauge wires. Could be simply the fact that the headlights are aftermarket and use smaller gauge wires
  2. #137
    bubbolootz is offline Cadillac Owners Member
    Automobile(s): 05 CTS-V
    May 2012
    3
    Re: Cts v dual halo aftermarket headlights.
    I thought that because I work at a gm dealership and I looked at a picture of the connector end views and I swear the connectors looked different so I thought I had to source out a harness from non hid and rewire it to the hid main harness in the vehicle. Guess not. Anyways I still grabbed one from the wreckers.
  3. #138
    Mar 2012
    156
    Quote Originally Posted by bubbolootz
    Let me know how this goes. I'm very interested in this idea
  5. #139
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Figured I'd drop an update in here. Still tweaking, but initial impressions are excellent. In person, the look of six vertical halos is pretty unique--even my BMW-driving friends did an abrupt 180° after seeing these things in person. I'll have better pictures later. For now, I'm just basking in the glow of:
    • Six 7000K CCFL halos
    • Two 55 watt 4500K projector headlights
    • Two 35 watt 4500K projector foglamps (not illuminated in these pictures)
    Before I forget--the color temperature depicted in these pictures is accurate. I double-checked. You get a nice, strong purple-blue-white flash as you move through the transition between the blocked and unblocked portion of the projection beam.
  6. #140
    aantalis's Avatar
    aantalis is offline Cadillac Owners Member
    Automobile(s): 2005 CTS V Stealth Grey 2008 Hot Lava
    Dec 2007
    Indiana
    41
    Very nice. What did you finally do with the wiring? Connect to spade terminals with wires cut from female connector? Did you solder and if so, exactly what? The spade terminals or just wire connections?. I will be starting mine this week, so any help is appreciated.
  7. #141
    Mar 2011
    2,045
    I cut out the connectors on both ends and spliced the wires.
  8. #142
    aantalis's Avatar
    Dec 2007
    Indiana
    41
    You cut out the connector at the headlamp? How did you fill the hole, protect the lamp from moisture?
  9. #143
    Mar 2011
    2,045
    Silicon sealant.
  10. #144
    May 2012
    3
    Hmm my buddy grabbed used harnesses for me at the wreckers, hopefully the right ones. The v is in the body shop il be going there this weekend to see if I can wire them up
  11. #145
    Mar 2011
    2,045
    Here's one more picture (below). I checked this for accuracy against real life--the headlights are a little green in the picture because of the camera's imperfect color correction. In reality, both the headlights and foglights look exactly like what you're seeing in the foglamp. Pure white core with the slightest hint of blue or purple.
  12. #146
    mike6466 is offline Cadillac Owners Member
    Automobile(s): 2006 cts v
    Jun 2012
    28
    43
    These look good
  13. #147
    ronr's Avatar
    ronr is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-V
    May 2004
    Fenton, Michigan
    870
    So, I installed a set of these (Angel Eyes from ebay) yesterday.
    First the good: They look great. Additionally, the wiring was pretty much plug and play. No cutting wires, no soldering. There was a small piece of the plastic on each headlight that needed to be trimmed off for the factory connector to go on correctly (this is used for mistake proofing the assembly in the factory so that the V Series and the standard lights don't get mixed up on the models.) Additionally, the passengers side light had a different connector on the light than the drivers side. The difference was that the pass side looked exactly like my factory light in that it did not have a plastic area raised between the 2 rows of electrical contacts in the connector. The drivers side did have this raised area. As a consequence, the drivers side connector on wiring harness had to have a small piece right behind the low beam contact (yellow wire) inside the connector removed. This was easily done with a small pair of needle nose pliers. After that everything just plugged in and worked like design (except for the headlight washers of course.)
    The bad news: The fit was not nearly as good as I had hoped but I'll live with it.
    NOTE: I've got an early '04 that came from the factory with 5 pin HID Ballasts. Perhaps the early V's used wiring more similar to the standard CTS's and that is why it was relatively easy for me to connect but I'm not sure.
  14. #148
    Mar 2011
    2,045
    With regards to the fit: if you push the headlight up and toward the back of the car when you tighten it down, it'll sit nicely. If you don't, it'll look bad.
  15. #149
    etcts-v's Avatar
    etcts-v is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V, 423 RWHP / 380 RWTQ
    Nov 2010
    Seattle, Washington,
    35
    578
    Quote Originally Posted by ronr View Post
    Plug and play with HID ballasts?? Are you running the stock ballasts?
  16. #150
    ronr's Avatar
    May 2004
    Fenton, Michigan
    870
    Quote Originally Posted by etcts-v
    The HID ballasts come with spade connectors that plug directly into the low beam light bulb connector (inside the light housing). The lights came with standard bulbs that need to be removed and replaced with the HID's.
  17. Remove Advertisements
