Shift knob
Results 1 to 8 of 8
2004-2007 Cadillac CTS-V Appearance Mods Discussion, Shift knob in Cadillac CTS-V Series Forum - 2004 - 2007; I have an 06 cts v can I retrofit an onine shift knob. Does anyone know?...
    HNIC661 is offline Cadillac Owners Member
    Automobile(s): 06 CTS-V
    Jul 2012
    So Cal
    33
    1
    Shift knob
    dangrus is offline Cadillac Owners Member
    Apr 2010
    Kansas City, MO
    94
    Re: Shift knob
    Search for some previous posts about shift knobs, there are a few of them that list the thread size. That would be the best way of knowing. I believe the last one I saw, there was mention about the Katech aftermarket being a different size. That will give you a keyword to help search with.
    Dan_Gurney is offline Cadillac Owners Fanatic
    Automobile(s): 07 - CTS-V
    Jun 2010
    Arizona
    407
    Re: Shift knob
    I was able to thread mine to match the C5 corvette shift knob, I just had to carefully sand the OD of the shaft down some, then I was able to tap it (i tapped right over the notch for the current shifter so i can still go back to stock if i want) I have pics i need to post sometime, i have an old school Hurst knob on mine
    DRod's Avatar
    DRod is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS-V :: K&N CAI | MAMO FAST 102 | KOOKS HEADERS
    Apr 2009
    San Antonio
    190
    Re: Shift knob
    I have a V2 (2009) shift knob in my 2007. You much reuse the V1 boot and bezel, and the V2 knob fits right in.
    Junior1's Avatar
    Junior1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V Racecar, 2011 Escalade ESV
    Jun 2008
    About to pass you...
    1,248
    Re: Shift knob
    There are no threads on the V1 shifter, UUC shifter or Katech shifter...
    The V2 (09+) shift knobs will fit right on the V1 (04-07) shifter. As mentioned before you need to remove the V2 knob from the boot by heating it (I used a heat gun on low setting) until there was enough play to pull it out. Then repeat the process with the stock V1 knob and boot to remove it. Follow up by popping the V2 knob into the V1 boot and replace. The hardest part is probably removing the knob from the shifter...
    There are a couple of threads with pictures in them just search for V2 shift knob
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,884
    Go with a Redline Goods custom shift boot...
    Skidmarcx's Avatar
    Skidmarcx is offline Cadillac Owners Fanatic
    Automobile(s): NONE!
    May 2011
    Phoenix, AZ
    39
    356
    Quote Originally Posted by thebigjimsho
    Agreed... I have one with stitching that matches the seats and it looks much nicer
    Apr 2010
    Kansas City, MO
    94
    Re: Shift knob
    I have no idea what I was reading about then.... I suppose I should shut up and watch when it comes to these shifters!
  11. Remove Advertisements
