Headlights
Results 1 to 10 of 10
2004-2007 Cadillac CTS-V Appearance Mods Discussion, Headlights in Cadillac CTS-V Series Forum - 2004 - 2007; Which HID ones do you guys replace your bulbs with? I have to take off my bumper and radiator out ...
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Headlights
    Which HID ones do you guys replace your bulbs with? I have to take off my bumper and radiator out to install my cam, so when I do that, I'll switch em out.
    Also, any good instructions/tips on removing the bumper? It looks hard, but isn't it just a few bolts and you just lift it off a certain way?
    2007ThunderV's Avatar
    2007ThunderV is offline Cadillac Owners Fanatic
    Automobile(s): 2007 cts v
    Jul 2011
    482
    Re: Headlights
    removing the bumper is actually really easy, iam down to ten minutes top now.
    there is 4 nuts, 2 on each side that will become visiable once you have the splash shields taken out. i think they are 3/8
    then all you do it use a trim tool and pop all the clips out, unhook the fog light harness, and your ready to pull the bumper cover right off.
    jclayc's Avatar
    jclayc is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS-V
    Sep 2008
    SC
    43
    418
    Re: Headlights
    The faq's instructions are good - http://www.cadillacfaq.com/faq/answe...val/index.html
    Izzmeister's Avatar
    Izzmeister is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS-V
    Nov 2006
    Miami
    108
    Re: Headlights
    Quote Originally Posted by lollygagger8 View Post
    The bulb is a D1s in the headlamps. I bought mine locally, paid about 100 bux for both bulbs. You dont want anything any cheaper than that, if not you have to do them again......pain in the arse.....trust me. I did my fogs HID 6k and my headlamps too also did the headlamp corner bulb with an LED. Dramatic diff in the way the car looks.....6k is a clear white light that looks classy and mean on the V.
    Apr 2008
    Indiana
    4,913
    Re: Headlights
    Ok, so where should I get 6k HID headlights?
    I have the bumper off while I'm doing my heads/cam/intake/TB install....so now's the time!
    I already did my fogs.
    Do I need a new ballast to run HID headlights? Or can I just plug and play? The search engine on this forum is pathetic.
    Apr 2008
    Indiana
    4,913
    Re: Headlights
    http://www.ddmtuning.com/Products/DDM-HID-Kit-D1SR-35W
    I found this......what color should I get to get a hint of blue? 6k?
    Bigtuna819 is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Oct 2011
    NJ/NYC
    31
    68
    Re: Headlights
    low beams are just plug n play, i ordered mine off ebay... $30, its been a year now and no complaints. I went 8k because I wanted a light blue tint
    carlson_mn is offline Cadillac Owners Enthusiast
    Automobile(s): Platinum 06 CTS-V, kooks, magnaflow
    Jul 2012
    MN
    34
    636
    Re: Headlights
    ddm tuning is cheap stuff and hit or miss. I've done a lot of business with them because they are cheap. If they last more than a few months you're probably go to go, but I've replaced a couple bulbs and ballasts between my lows and fogs on my altima.
    Do NOT go anything more than 6k unless you just want a ricey look, not to mention actual output lumens goes downhill once you go past 5k. Think of driving around with black lights for headlights = 10k. 6k looks great and does perform fairly well but is not picked up by the human eye with as much contrast as 4300k (stock) or 5k (good compromise looks and performance).
    I plan on putting 3k HIDs into the fogs. Bright yellow and looks great on the road / snow!
    Jul 2012
    MN
    34
    636
    Re: Headlights
    Oh, and because your car has factory HIDs with ballasts you'll only need bulbs, not that whole kit with a wiring harness and new ballasts. just in case... http://www.ddmtuning.com/Products/HI...lacements-Pair
    While we're at it - what type of bulbs are in the fogs? edit: H10 / 9145
    Apr 2008
    Indiana
    4,913
    Re: Headlights
    Quote Originally Posted by carlson_mn View Post
    Thank you Sir!
  13. Remove Advertisements
