Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: KW variant 3
    isakhanyan is offline Cadillac Owners Fanatic
    Automobile(s): ATS Turbo Manual
    Feb 2009
    San Jose, California
    28
    126
    KW variant 3
    Hey everyone,
    I need to get new shocks, mine are going bad. I have ground control coilover kit now but I have decided to just get the KW variant 3. How hard is the installation process? Where can I get them the cheapest?
    jclayc's Avatar
    jclayc is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS-V
    Sep 2008
    SC
    43
    418
    Re: KW variant 3
    Hey - I just finished installing the KWv3 on my 05 V... I bought mine for $2033 shipped from tunedcustoms & they arrived in 3 days - http://myworld.ebay.com/tunedcustoms...84.m1497.l2754
    The instructions for the ground control kit pretty well sum up what's involved: http://www.cadillacfaq.com/faq/answe...all/index.html. I'm no pro, so it took me around 5-6 hours for the front and 2 hours for the rear. That's mostly to BS like a stripped wheel stud and strut tower bar bolt...
    The only thing that I'd change from those instructions is that you don't have to drop the rear cradle to remove the rear springs. Once you've gotten the rear shock bolt off and . the 21mm bolt holding the control arm, the spring perch will drop but not quite enough. Remove your rear end links and loosen the sway bar - that'll let you swivel it out of the way and you can then pull the springs out. Also, with the KW3 kit on the rear, you'll need to pry out the upper and lower rubber spring mounts.
    Last thing I'll say is, for me, I set the front springs waaaay too low out of the box. It made front spring install easier but I ended up having to go in and re-adjust upward.
    kciaccio is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS-V
    Apr 2012
    47
    154
    Re: KW variant 3
    Awesome. let us know how it drives after. Thanks!
  5. #4
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,463
    Re: KW variant 3
    I had put a nice, detailed "how to" in this thread - http://www.cadillacforums.com/forums...led-today.html - but that thread appears to be gone for some reason. (I found the link to it in another thread about KWs.) I just sent a note the site administrator to see if there's anyway that thread can be recovered; it had plenty of good info about the install and feedback on performance and ride quality from a few different KW users.
    Long story short, installing the KWs is no different than installing any other struts/shocks. They include pretty detailed instructions, including very specific measurements on where to set the spring perches so that your ride height is good from the start. (jclayc, did you not get those instructions, or did you just not see/use the part about setting the spring perch heights?)
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  6. #5
    Nov 2011
    www.PresenceDistribution.com
    227
    Re: KW variant 3
    We can get you a set of KW coilovers, send an email/PM.
  7. #6
    jclayc's Avatar
    Sep 2008
    SC
    43
    418
    Re: KW variant 3
    hmmm, there were instructions with my kit but they were either how to set the dampning/rebound or what parts to keep off the existing shocks. (Only like 2 pages of actual instructions instead of warnings in German.) I'm at a good height now, I believe.
    It's tough for me to make a clean judgment on the KW3s because I also installed Hotchkis sways and new endlinks but, compared to the FG2s (which were a BIG improvement) there's much less body roll & the ride quality is still good. I need to adjust my rebound settings a bit softer because of some chattering over bad road but that's just part of getting them broken in.
    My only issues, one related one probably not related: I've checked all my bolts but it sounds like something's looser than it was when I go over big bumps. My next issue is that I got the car from the hand wash this AM and my stability system message came on w/ tc and abs now lighting up on the dash. ugh
  8. #7
    AAIIIC's Avatar
    Aug 2007
    6,463
    Re: KW variant 3
    Quote Originally Posted by AAIIIC View Post
    Thread restored (thanks to JimmyH).
    Quote Originally Posted by jclayc View Post
    I suppose it's a moot point if you've gotten the suspension set up already, but there should have been 2 sets of instructions - 1 detailing how to put them on the car, and 1 detailing ride heights and damping adjustments. Their website has them both listed - here's the right height / damping instructions.
  9. #8
    ahahnu's Avatar
    ahahnu is offline Cadillac Owners Connoisseur
    Automobile(s): '05 LS6 V Stealth Grey; '14 Z71 SLT Sierra 1500 Stealth Grey
    Dec 2004
    Tailgating at Giants Stadium
    37
    2,821
    Re: KW variant 3
    I love my KWs, I'd buy them again.
  10. #9
    May 2012
    30
    7
    Re: KW variant 3
    Quote Originally Posted by isakhanyan View Post
    Hey everyone,
    Are you willing to sell your Ground Control Kit? What shocks where they for? I am currently looking for a GC kit - figured might can help you on the cost for the KW V3s
  11. #10
    shadybx7's Avatar
    shadybx7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Platinum CTS V-Headers+3in pipes
    Apr 2008
    3,014
    Re: KW variant 3
    Let us know if you find it cheaper then $2Gs..
    good thread here:
    Quote Originally Posted by 2006CTSV View Post
    stock shocks
  12. #11
    PISNUOFF Guest
    Re: KW variant 3
    The question should be, what spring rates. 600F/650R is perfect. I went with 500/550 with my stock shock and they were too soft.
  13. #12
    Feb 2009
    28
    126
    I'm replacing them bc I need new shocks, I can sell you the ground control kit once I get a set of the kw's
  14. #13
    May 2012
    30
    7
    Re: KW variant 3
    Quote Originally Posted by PISNUOFF View Post
    yea - true that. how can i contact you about a short throw? looking to get one soon...
    - interested - what is the spring rate? and what shocks were they for (need them for fg2's)
    thanks
  15. #14
    Feb 2009
    28
    126
    thanks
    I have the fg2's but I don't remember what the spring rate is. How do I check that?
  16. #15
    Feb 2009
    28
    126
    Another question for you guys, I have the hotchkis sway bar and the z06 end links, will I have a problem?
  • You may not post replies
