Rocker Panel HELP...
Results 1 to 6 of 6
2004-2007 Cadillac CTS-V Appearance Mods Discussion, Rocker Panel HELP... in Cadillac CTS-V Series Forum - 2004 - 2007; One of the clips busted on my passenger side rear rocker panel and I don't know how about fixing it. ...
    thefulmonty_07 is offline Cadillac Owners Fanatic
    Automobile(s): 05 CTS-V
    Jul 2010
    Sierra Vista, Arizona
    117
    One of the clips busted on my passenger side rear rocker panel and I don't know how about fixing it. I know they're held on by a few clips and I can purchase them them through Luke, but I don't know how to install it.....do I have to break the rest of the clips and redo all of them or is there a way I can just fix the one that is broken? I appreciate any info or help, Thank you
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,156
    Re: Rocker Panel HELP...
    As close as I can get is the wheelhouse liner. See attached.
    Jul 2010
    117
    Hey thanks for the info, i'll try and put it to use.
    cts-v avino is offline Cadillac Owners Member
    Automobile(s): 07 CTS-V
    Nov 2009
    CT
    38
    Same thing happened to mine. I used 5 minute epoxy and pushed it in with a 2x4 against the wall in my garage to apply pressure. Just make sure you clean it the best you can with some rubbing alcohol.
    BirdmanTamu's Avatar
    BirdmanTamu is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS-V
    Oct 2007
    Houston, TX
    36
    188
    I've fixed this before but it was a loooong time ago. I believe you have to remove the broken clip out of the rocker panel and slide/insert a new one. Once it's replaced it's literally a snap.
    Jul 2010
    117
    Nice, i'll just have order a clip from Luke and try just replacing the one....Thank you for the help!
  9. Remove Advertisements
