Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
Thread: Headlight Restoration
  1. #16
    OneFast V is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Raven Black CTS-V
    Mar 2010
    San Jose, CA
    30
    979
    Re: Headlight Restoration
    Quote Originally Posted by WarrenMRogers View Post
    I had excellent results with the Turtle Wax "by hand" kit. It was $9.95 but it only lasted about two weeks! I used it on my wife's Jeep Grand Cherokee and it turned her lights from yellow to sparkling like brand new. I am going to try again and throw some meguiar's wax on it and look into a clear coat and see if it lasts any longer! The worst part is it is only one headlight that is bad, it looks awful.
    The turtle wax by hand kit cannot compare to the 3m kit which is well worth the extra $10
  2. #17
    CancerJCC is offline Cadillac Owners Connoisseur
    Automobile(s): 04' Blown CTS-V 554rwhp 497rwtq
    Aug 2009
    Georgia
    1,786
    I don't see why spraying some rattle can clear wouldn't work. If it doesn't come out clear enough then just wet sand it some and polish back to luster, a step you'd probably have to do anyhow.
  3. #18
    Sublime69 is offline Cadillac Owners Fanatic
    Automobile(s): None
    Aug 2009
    35
    134
    Save your money on all the kits... I just bought 1000, 1500 and 2000 grit wet/dry sand paper... Started with 1000 and worked my way up.. after i just used my buffer and some 3M finesse-it II compound. Came out like new... and my headlights were REALLY bad. All cracked and faded.
  4. #19
    Larimer is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Feb 2012
    Novi, MI
    31
    71
    I'm interested in doing this but want to find a good solution for clearing them first. Can't seem to find much on the web.
  5. #20
    DRod's Avatar
    DRod is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS-V :: K&N CAI | MAMO FAST 102 | KOOKS HEADERS
    Apr 2009
    San Antonio
    190
    I posted some pics and a little about how I did it awhile back. When I get some time, I'll hunt it down.
    EDIT: (hunted down the photos)
    Before
    Halfway through the sanding process (I peeled the painters tape off since it was drenched, and reapplied at this point.)
    Sanding complete
    Finished product (After buffing and compound, and application of the epoxy.)
    Basically, I wet sanded the headlights by hand starting with 400 > 600 > 800 > 1000 > 1400 > 2000. The last two come in the Meguiars headlamp restoration kit. With each grit, I sanded either vertically or horizontally, alternating with each level. After you're done sanding off all the oxidation and scratches, you can buff it out with a wool cutting pad and some rubbing compound or a good polish. That should bring back the shine. Protecting them long term and preventing the crud from coming back is the hard part.
    Since I did mine (which look brand new), Diamondite has these kits that apparently blow away anything else out there. The kits come with the tools (minus the drill or buffer) that you need to buff the crud out without sanding. Although I think sanding really helps knowing how much oxidation I had on my lights.
    In the end, I had a pro help me with the last piece of the puzzle. He showed me how to use the compound and drill with wool cutting pad to bring back the shine, and he applied an epoxy or polymer. The Diamondite kit includes a similar product called "Liquid Armor" that takes care of this issue.
    I have yet to use the kit, but I did order one and I plan to use it on a friend's G35 and on another CTS-V here in town. Here's the link: http://www.diamondite.com/diamondite-kits.html
  6. #21
    Faber is offline Cadillac Owners Fanatic
    Automobile(s): None :(
    Aug 2011
    Cincinnati, OH
    38
    407
    Quote Originally Posted by Larimer View Post
    what do you mean? The 3M kit is pretty good.
  7. #22
    CTSV_510's Avatar
    CTSV_510 is offline Cadillac Owners Connoisseur
    Automobile(s): '06 Z06, '05 CTS-V 453rwhp/434rwtq (sold)
    Jan 2008
    West Chester, PA
    34
    4,455
    Quote Originally Posted by Faber View Post
    I think he means clear coating them to protect them in the future.
    I just did my headlights with the Meguiars kit and they turned out great. It only took about 20 minutes too.
  8. #23
    Aug 2011
    Cincinnati, OH
    38
    407
    Quote Originally Posted by CTSV_510 View Post
    oh yeah. oops.
  9. #24
    DRod's Avatar
    Apr 2009
    San Antonio
    190
    Just used the Diamondite kit over the weekend, and it's amazing! I'd consider that over the 3M or Meguiars kits, both of which I've used in the past.
  10. #25
    Aug 2011
    Cincinnati, OH
    38
    407
    Here's the headlights - been approx 7 months. I think they seem to be holding up well. Only thing I've done is a coat of wax every once in a while.
  11. #26
    bneal1022's Avatar
    bneal1022 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS-V, K&N, Borla, short throw w/ Holden knob, hotchkis
    May 2009
    40
    906
    My vinyl overlays (on the gray surround) still look like new after 18 months. Never had a problem with the clear lens portion.
  12. #27
    JD03Cobra's Avatar
    JD03Cobra is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 Thunder Gray 6MT
    Mar 2008
    Michigan
    44
    2,122
    Quote Originally Posted by DRod View Post
    In the end, I had a pro help me with the last piece of the puzzle. He showed me how to use the compound and drill with wool cutting pad to bring back the shine, and he applied an epoxy or polymer. The Diamondite kit includes a similar product called "Liquid Armor" that takes care of this issue.[/URL]
    I used the Mequiars Kit which worked pretty good but I just couldn't get them to shine up really well. I need to find something else.
  13. #28
    Icypizit is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac CTS 3.6 "Rob" Volant Cold Air + more
    Nov 2012
    Edinburg, TX
    23
    So, where is this "pro" located or what's his business called? My headlights are oxidized pretty bad, and I've tried 3 different cleaners, even the Meguiars drill kit, and it didn't work, but this guy sounds like he can fix them, and I wouldn't mind driving up there and paying 100 bucks because there's nobody in my area that does headlight restoration here.
  14. #29
    carlson_mn is offline Cadillac Owners Enthusiast
    Automobile(s): Platinum 06 CTS-V, kooks, magnaflow
    Jul 2012
    MN
    34
    636
    I tried the Turtle wax kit and I also was not able to get the tops from looking all frayed and dry. They did make an improvement though but I'm still looking for a better tool to finish the job
  15. #30
    1yakini's Avatar
    1yakini is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Nov 2012
    Hampton Roads, Va
    38
    64
    Quote Originally Posted by johnny6 View Post
    I used the same kit with amazing results, i also used them on my Jeep Cherokee and i'm very pleased. I've tried pretty much every kit out there and 3M is the best by far.
    I thought Jeep headlights come from the factory hazy
  • You may not post replies
