Spacers and advice needed......
Results 1 to 11 of 11
Like Tree1Likes
  • 2 Post By GDPossehl
2004-2007 Cadillac CTS-V Appearance Mods Discussion, Spacers and advice needed...... in Cadillac CTS-V Series Forum - 2004 - 2007; I've decided to go 255/45R18 on all four corners. For several reasons... That being said I really like how the ...
    Sullyfx is offline Cadillac Owners Fanatic
    Automobile(s): 05' CTS-V Platinum
    Jul 2011
    South Carolina
    137
    I've decided to go 255/45R18 on all four corners. For several reasons... That being said I really like how the front tires are nice and flush with the wheel wells. The Rears are not however.So the question is. what size spacer do I go with to get them flush.
    Also what brand / place do I get them from? I have no experience with this type of mod. The picture is of the rear with 245/45R18, for reference.
    Thanks for any and all help
    EdmundGTP is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 CTS-V
    Aug 2009
    Tempe AZ
    35
    612
    Re: Spacers and advice needed......
    Get the tires put on and double check all your clearances before you go putting wheel spacers in.
    Jul 2011
    South Carolina
    137
    I have spoken to others about clearance with the 255's. No problems there even lowered. I am all stock so I dont think it will be an issue? Am I mistaken?
    Also: a 255 is only .6" wider
    JD03Cobra's Avatar
    JD03Cobra is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 Thunder Gray 6MT
    Mar 2008
    Michigan
    44
    2,122
    I'm running 275's out the back on stock rims. No clearance issues at all. Actually with the wider tires it looks more flush with the rear. Forget the spacers.
    Jul 2011
    South Carolina
    137
    If your running 275's in back I assume there 40 series.... What are you running up front?
    JD03Cobra's Avatar
    Mar 2008
    Michigan
    44
    2,122
    Quote Originally Posted by Sullyfx View Post
    Stock size up front and yes 40 series in the rear.
    Jul 2011
    South Carolina
    137
    That looks pretty good. its a tough call though... Do I go with the same size all around to get more life out of the tires, because I can rotate....
    With the 40 in back vs. the 45 up front do you notice a height difference in the sidewalls? It is pretty slight...
    Also have you thought about my offer on the clear fogs?
    GDPossehl is offline Cadillac Owners Enthusiast
    Automobile(s): '04 CTS-V
    Feb 2011
    Decatur, GA
    507
    If wider tire's don't do it a 1/4" spacer will.
    http://www.wheeladapter.com/wheel_spacers.php
    I'm running 1/4" spacers on my sts-v wheels. The rears are perfectly flush with those and a 275 tire.
    Sullyfx and Sullyfx like this.
    Jul 2011
    South Carolina
    137
    Thanks "GDPossehl". I appreciate the info. I will look into them.
    Feb 2011
    Decatur, GA
    507
    You may need longer studs too.
    Jul 2011
    South Carolina
    137
    I am being told that as long as you don't go any bigger than a 1/4th spacer you wont need longer studs..... I would think that would be max size spacer anyways for what I want.
  14. Remove Advertisements
