H&R Springs - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
2004-2007 Cadillac CTS-V Appearance Mods Discussion, H&R Springs in Cadillac CTS-V Series Forum - 2004 - 2007; Some pics of the 'Edmod' that I did today. Makes the H&R's perfect height, IMO....
  1. #16
    WesH8398's Avatar
    WesH8398 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2010
    Sarnia, Ontario, Canada
    35
    897
  2. #17
    Scotty_R8 is offline Cadillac Owners Member
    Aug 2011
    5
    Re: H&R Springs
    what material was used for the "edmod"
  3. #18
    Sullyfx is offline Cadillac Owners Fanatic
    Automobile(s): 05' CTS-V Platinum
    Jul 2011
    South Carolina
    137
    Re: H&R Springs
    I'm new and uninformed so I will ask...
    When getting the H&R springs, I assume you then only need the MM spacers for the rear to equal out the stance front and back
    Than, is there anything else needed when installing the springs? I assume the stock shocks will work. Until I can get better?
    Thanks
  5. #19
    EdmundGTP is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 CTS-V
    Aug 2009
    Tempe AZ
    35
    612
    Re: H&R Springs
    Quote Originally Posted by Sullyfx View Post
    Thanks
    Your assumed reasoning behind the need for the MM spacers is incorrect. Without explaining why, I'm just going to tell you that you need them and you should install them. There are dozens of other threads on here that explain their purpose.
    Stock shocks are fine, unless they're worn the hell out.
  6. #20
    Jul 2011
    South Carolina
    137
    Re: H&R Springs
    Well said, thank you
  7. #21
    cam3439 is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Nov 2010
    106
    Re: H&R Springs
    Quote Originally Posted by WesH8398 View Post
    Where did you get your V emblems or is that just an overlay? What material did you use for the 'EDmod' and do you remember the inner and outer diameter?
  8. #22
    Aug 2009
    Tempe AZ
    35
    612
    Re: H&R Springs
    Quote Originally Posted by cam3439 View Post
    Read here, beginning to end.. http://www.cadillacforums.com/forums...-lowering.html
    Not sure where his badges are from.
  9. #23
    WesH8398's Avatar
    Apr 2010
    35
    897
    Badge overlays are from 8th Day Creations. Search them on this forum and you shall find.
    As for measurements of the rear spring spacer, all you need to do is a) read Ed's post that he linked above, and b) use the lower spring isolator that sits on this spacer as a stencil to trace the 2 circles onto the 60 durometer rubber that you'll buy after you read Ed's thread.
  10. #24
    Nov 2010
    106
    Re: H&R Springs
    Thanks.
  11. #25
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Re: H&R Springs
    Wes, what size tires are you running on the back? Any rubbing?
  12. #26
    WesH8398's Avatar
    Apr 2010
    35
    897
    Quote Originally Posted by lollygagger8 View Post
    19x10 with 275/35-19 tires. And yes. lol it's all straightened out now tho. If you want more info, search threads started by me. There are 3 or 4 separate threads that all have to do with different fitment issues I was having. If they're not on this forum, they're over at ls1 tech.
  13. Remove Advertisements
