Shift Knob Fail - Help!
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
2004-2007 Cadillac CTS-V Appearance Mods Discussion, Shift Knob Fail - Help! in Cadillac CTS-V Series Forum - 2004 - 2007; So back in October I ordered the UUC short shifter and suede V2 knob from Lindsay. About the same time ...
    pharoh is offline Cadillac Owners Member
    Automobile(s): '07 CTS-V
    Nov 2009
    Central NJ
    63
    So back in October I ordered the UUC short shifter and suede V2 knob from Lindsay. About the same time I ordered the black suede/light grey stitched shiftboot from RedLine goods, but because it ships from Europe I received it a week after the SSK/v2 knob. Being the impatient soul I am, I installed the UUC Short Shifter and v2 knob the day after I got it. Now, no matter what I do, I *CANNOT* get the darned v2 knob off the UUC shifter to install the boot. I was able to get the stock knob off the stock shifter w/ no issue. But this, I've literally spent several evenings trying to pull/yank/pry from underneath with channel locks with no luck.
    I've marred the base of the v2 knob (which you don't see under the boot) and the beautiful (otherwise unseen) machined finish of the UUC shaft with no luck in getting the knob off. Now I have a $55 shift boot I can't install short of destroying the $120 v2 knob, FML! I've installed my Magnaflow catback and UUC shifter by myself, as well as countless other mods on past cars. I can't believe I've been defeated by a darn SHIFT KNOB!!!
    </rant>
    Anyone here have any advice as to how I can go about this? I've tried the push up toward 5th and pull back towards 2nd methods (the towards 2nd method is how the stock shift knob came off). I'm about to open a FS thread on the darned shift boot otherwise 'cause its getting to be more trouble than its worth.
    Castro's Avatar
    Castro is offline Cadillac Owners Fanatic
    Automobile(s): None
    Jan 2005
    DC
    34
    447
    Re: Shift Knob Fail - Help!
    HA! Yep. Same thing happened to me and about everyone else that's tried to remove the V2 knob. My advice is open the sunroof, stradle the center console, and stop babying it (j/k). There is no real secret other than brute strength, don't use tools just muscle it. Mine finally came off randomly after many attempts. Try it every morning and you'll have a new boot by Christmas.
    CancerJCC is offline Cadillac Owners Connoisseur
    Automobile(s): 04' Blown CTS-V 554rwhp 497rwtq
    Aug 2009
    Georgia
    1,786
    Quote Originally Posted by Castro View Post
    Troof. The UUC is the worst to get shift knobs off and I can attest to that. I have had mine off a few different times and it doesn't get any easier subsequently! Why in the heck do we not have threaded knobs like the rest of the world?!
    G/L OP just eat yer wheaties and go to town.
    Nov 2009
    Central NJ
    63
    Quote Originally Posted by CancerJCC View Post
    LOL Thanks guys! So which method have you had the most success with, pulling up and towards second gear?
    RoverGuy7 is offline Cadillac Owners Member
    Automobile(s): 05 CTS-V
    Jun 2010
    62
    i found it to be easier if you twist back and forth while pulling up, still needs a lot of force, but put it in second, pull and try to kind of twist back and forth on the knob
    BirdmanTamu's Avatar
    BirdmanTamu is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS-V
    Oct 2007
    Houston, TX
    36
    188
    That's what I was gonna say too. While steadily pulling with all your might: try twisting the handle slightly CW/CCW. Eventually that worked for me, and I too had more difficulty getting the V2 knob to liberate from the UUC shifter. There's a groove cut in the shift lever the knob clips to. The purpose of pulling or twisting at a certain angle is to unseat/unclip the knob from the notch.
    I do recall almost giving myself a hernia and putting at least 100 lbs of upward pressure on that darn knob before it gave way...then I had to change my pants.
    STOP with the channel locks on your purdy new V2 knob! The portion of it that clips to the shifter is plastic.
    Nov 2009
    Central NJ
    63
    Quote Originally Posted by BirdmanTamu View Post
    I kid you not when I say the first evening I was tugging so hard for a good 45 minutes that my shirt was soaked and my whole arm/shoulder was sore for the next 2 days. The only thing that came out of that session was a good crap immediately after. LOL!
    The channel lock thing I tried was from underneath the shift boot side. The UUC has that flat ledge that I tried to use as leverage. I'll try the twist action tonight and see if I get any luck. I'll get this shift boot on yet!!!
    Nov 2009
    Central NJ
    63
    You guys ROCK! The twisting action did the trick and it was fairly easy! The new shiftboot is now ON!
    CadzillaTN's Avatar
    CadzillaTN is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Apr 2008
    2,061
    might as well post a pic or two..
    Nov 2009
    Central NJ
    63
    Ask and you shall receive!
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,823
    Well, it was worth the grief. Looks great!
    CadzillaTN's Avatar
    Apr 2008
    2,061
    I agree. I don't think anyone has this combo yet.. the boot was a good addition.
    SRTTOCTSV is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Nov 2010
    52
    Nice!!! I might go this route......
  16. #14
    zzilla is offline Cadillac Owners Fanatic
    Automobile(s): cts v-xlr v
    Jan 2009
    158
    Quote Originally Posted by SRTTOCTSV View Post
    the boot is a different color suede than then the V2 knob The boot has a black /Reddish purple tint where as the V2 knob has a black Green tint. I am Looking into getting the boot dyed to match closer to the knob.
  17. #15
    jeffthenail is offline Cadillac Owners Member
    Automobile(s): 07 TG V1
    Mar 2010
    Nor Cal
    89
    Does this mean that you are going to remove it again?? Perhaps a video for us to watch the fun this time!!
  18. Remove Advertisements
