New set of tires, Need help
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
2004-2007 Cadillac CTS-V Appearance Mods Discussion, New set of tires, Need help in Cadillac CTS-V Series Forum - 2004 - 2007; I'm looking to get a new set of tires and have a few questions... I wanna run wider tires in ...
    07 Velocity is offline Cadillac Owners Member
    Automobile(s): 2007 CTS-V
    Oct 2010
    28
    8
    I'm looking to get a new set of tires and have a few questions... I wanna run wider tires in the back so I was wondering if I should do 255 or 265 width and should I keep the stock 45 or drop down to 40... I don't want a big gap in between the tires and the car.
    My goal was to go 265 40 18 in the back and keep the stock 245 45 18 in the front... Would that set up not look right, or will it work fine? Thanks in advance!
    tweeter81's Avatar
    tweeter81 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Mar 2005
    Gillette, WY
    35
    1,620
    Re: New set of tires, Need help
    If you are going to go staggered you might as well get the biggest tire you can fit back there. I have run 4 different tire size combos on my V, so I know what's up.
    I would strongly recommend running a 275/40r18, as that tires overall diameter is only 0.8% different than the stock 245/45r18.
    Or you could drop down on the sidewall thickness a bit (for crisper handling and much better looks) and use 245/40r18 front and 275/35r18 rear. That is the option that I would personally choose. This option's overall diameter is about 0.8" shorter than the stock size, which would in effect lower the whole car that much and improve handling characteristics.
    whisler151's Avatar
    whisler151 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 CTS-V Sedan, 2011 CTS Coupe, 2010 Ford Raptor
    Apr 2007
    Dallas, TX
    3,547
    245/45 18 front and 275/40 18 rear
    If lowered you can do 245/40 18 front 275/35 18
    Oct 2010
    28
    8
    275's wont rub?
    Stepside is offline Cadillac Owners Enthusiast
    Automobile(s): '06 DTS performance; CowboyCadillac='12 SVT Raptor
    Oct 2009
    NW Jerzey-in the sticks
    67
    631
    275s on an 8 1/2" wide wheel ??
    It fits.
    It works.
    It looks ok.
    recommeded . . not really.
    Tire width spec. has a wheel width spec. to match the engineering specification of tire design . . aka sidewall stress and tread contact/wear.
    BigMac0603 is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Aug 2010
    7
    I completely agree but most people are only going for the look of the widest tire even if it means it won't perform as well as a smaller tire on the same rim.
    Quote Originally Posted by Stepside View Post
    It fits.
    It works.
    It looks ok.
    yamahaRwon is offline Cadillac Owners Member
    Automobile(s): 04 cts-V
    Oct 2010
    34
    how wide of a tire can you do on the stock rear wheel with out going too wide for good performance>
    Oct 2010
    28
    8
    I think I am going to do 265 40 in the rear and keep the 245 45 in the front... I plan on lowering the car also. Will the lowering kit affect the performance shocks?
    tweeter81's Avatar
    Mar 2005
    Gillette, WY
    35
    1,620
    Quote Originally Posted by yamahaRwon View Post
    search for answer on google
    tweeter81's Avatar
    Mar 2005
    Gillette, WY
    35
    1,620
    Quote Originally Posted by 07 Velocity View Post
    no, for more information search on google
    Oct 2009
    67
    631
    LightbulbRe: New set of tires, Need help
    Go to tirerack.com and pick the tire you want.
    Then, click on Spec.
    When you view the specifications, there will be recommended wheel widths (minimum to maximum) for all size tires . .
    . . And a whole lot of other good information.
    BadVMan's Avatar
    BadVMan is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac V BAd BOy
    Apr 2008
    Louisiana
    191
    I have two BFG KDW's for sale cheap in the classified section for $80 each plus shipping with 80%+ treadlife on them and they are 245/45 18 or 245/40/18's I cant remember exactly but I can find out tonight if you are interested. They would be good for your fronts and would save you alot of $$. Just let me know and PM me if interested, ty Jim
    odla's Avatar
    odla is online now Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,372
    What would you guys recommend for a car lowered on ground control? As far as it can go down. I want wider tires that i can rotate all 4 corners. this cars See's track time 6 times a year about. I'm in the middle of the search function and found this so i thought i would ask.
    thanks
  16. #14
    WesH8398's Avatar
    WesH8398 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2010
    Sarnia, Ontario, Canada
    35
    897
    To the OP and anyone else experimenting with tire sizes ... GO HERE. I use that thing constantly.
  17. #15
    tweeter81's Avatar
    Mar 2005
    Gillette, WY
    35
    1,620
    It fits.
    It works.
    It looks ok.
    First Gen V owners have been running the 245/275 tire size setup for years, and I have never heard any complaints (and I've basically checked this forum daily since I signed up in March of 2005).
  18. Remove Advertisements
