Destroying Led's
Results 1 to 10 of 10
2004-2007 Cadillac CTS-V Appearance Mods Discussion, Destroying Led's in Cadillac CTS-V Series Forum - 2004 - 2007; I have swaped out all of the bulbs on my V and I seem to be burning out the Driver ...
    blackax is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Jan 2010
    30
    93
    Destroying Led's
    I have swaped out all of the bulbs on my V and I seem to be burning out the Driver side tail lights (only half of the led will light up when i supply 12 v)
    I dont have any problems when I install a glass bulb
    Jan 2010
    30
    93
    Re: Destroying Led's
    Bump
    calidave's Avatar
    calidave is offline Cadillac Owners Fanatic
    Automobile(s): '05 CTS-V
    Jul 2008
    36
    250
    Try installing a resistor. LEDs draw less current and it may be the system thinks a bulb is out. You can find resistors all over the place, but I bought mine from V-LEDS.
    jmpumford's Avatar
    jmpumford is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Maggied CTS-V
    Oct 2010
    Los Angeles, CA
    34
    253
    How do you like them btw? (other than the burning out of course)
    Riverside is my hometown, I'm curious how they look.
    Jan 2010
    30
    93
    I have a resistor on my turn signal and that got destroyed as well....Plus its only happening on one side of the car.
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    I havent had any issues with my LEDs, i installed them on the brake lights/ runnin lights as well as reverse..Not to mention the License place and side markers as well...
    I havent had any failures as of yet...
    Check the fuses, and the voltage comin off that line, you may have a spike causing them to burn out.
    Jan 2010
    30
    93
    Quote Originally Posted by Naf View Post
    Its getting the right voltage (that was the first thing i checked) i've thought of changing out the fuse to a smaller one and see if that has an affect (its starting to get a bit of $$)
    Stepside is offline Cadillac Owners Enthusiast
    Automobile(s): '06 DTS performance; CowboyCadillac='12 SVT Raptor
    Oct 2009
    NW Jerzey-in the sticks
    67
    631
    You guys with the L E D's. Does your turn signal flash at a different rate ? & I thought a different relay was necessary.
    Since, amps = volts/resistance and L E D s have less resistance, would not there be an amperage increase with 12v applied causing the burn out problem?
    What is the wattage of the L E D. Volts X Amps = Watts
    ccclarke's Avatar
    ccclarke is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC CE, '04 CTS-V, '04 XLR, '13 XTS Platinum
    Apr 2004
    Uncanny Valley, New England
    1,698
    Quote Originally Posted by blackax View Post
    The fuse isn't the issue. You need the proper current limiting resistor to protect teh LEDs.
    CC
    Jan 2010
    30
    93
    I have one on the flasher and it did the same thing
  13. Remove Advertisements
