Tire Size for Team Dynamics Wheels (18x9) - Page 2
Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 61
Like Tree1Likes
2004-2007 Cadillac CTS-V Appearance Mods Discussion, Tire Size for Team Dynamics Wheels (18x9) in Cadillac CTS-V Series Forum - 2004 - 2007; I just bought a set of these wheels from Luke @ Lindsay and they did indeed come with center caps ...
  1. #16
    tweeter81's Avatar
    tweeter81 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Mar 2005
    Gillette, WY
    35
    1,620
    Re: Tire Size for Team Dynamics Wheels (18x9)
    I just bought a set of these wheels from Luke @ Lindsay and they did indeed come with center caps (but he tells you that they don't, so this must be a recent change that TD has made). I haven't installed the wheels yet, but I assume the center caps will clear everything (based on an earlier post).
    A couple other points of interest:
    1) I measured the wheel width and they are actually 9.75" wide. I always thought a 9" wheel was exactly 9" wide, but apparently not.
    2) The TD wheels feel heavier than my CCWs (even the wider rear 19'x10") - those CCWs are super light
    3) I will be running 275/35zr18 r-comps (R888s) on all 4 corners. I'm lowered, but I have had all the fenders rolled, so I don't really expect to have rubbing issues, or if I do, they will be very minor and only under track conditions.
  2. #17
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    My TDs came with center caps as well. They look like they can stay on even at the track (we'll find out). I'm running 275/35/18s Conti (Hoosier) Grand Am Cups.
    Look like this. I've posted this picture a million times it seems. As you can tell I must like them.
  3. #18
    Feb 2007
    Cheese land
    1,596
    Quote Originally Posted by tweeter81 View Post
    Empty your inbox Tweeter.
  4. #19
    Junior1's Avatar
    Junior1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V Racecar, 2011 Escalade ESV
    Jun 2008
    About to pass you...
    1,248
    Quote Originally Posted by AAIIIC View Post
    245/45-18
    My bad, I should clarify. I'd like to get a dedicated track tire in R compund or slick. Something close to stock sizing since I haven't seen any yet.
  5. #20
    tweeter81's Avatar
    Mar 2005
    Gillette, WY
    35
    1,620
    Quote Originally Posted by crankedupforit View Post
    Done. BTW, That pic you posted above is sweet as hell!
  6. #21
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,150
    The advertised wheel width (9" in this case) is the width at the the tire beads. Every wheel you put a measuring tape on will be somewhere around 1" wider than the advertised width because the inner and outer lips of the wheel extend beyond where the tire beads ride. The various wheels I've measured over the years were anywhere from 7/8" to 1-1/8" wider than the advertised width.
  7. #22
    tweeter81's Avatar
    Mar 2005
    Gillette, WY
    35
    1,620
    That is good to know
  8. #23
    AAIIIC's Avatar
    Aug 2007
    6,150
    Quote Originally Posted by Junior1 View Post
    The closest (only) options are either 245/40-18 or 275/35-18. Actually, I think Toyo makes the R-888 in 275/40-18, which would match the stock diameter, but since we're worried about fender clearance with the 275s up front I just figured it makes more sense to run a 275/35.
  9. #24
    nikon's Avatar
    nikon is offline Cadillac Owners Connoisseur
    Automobile(s): 05' CTS-V
    Feb 2006
    Palm Beach Gardens, FL
    31
    3,718
    Anyone lowered with H&R's with 275/35/18 up front? Or all around in that case? Wondering if street tires are different that crankedupforits tires.
  10. #25
    tweeter81's Avatar
    Mar 2005
    Gillette, WY
    35
    1,620
    Quote Originally Posted by nikon View Post
    Street tires are narrower (a 275 street tire is equivalent to a 265 racing tire) and the street tire don't have the square edges like the racing tires have.
  11. #26
    Junior1's Avatar
    Jun 2008
    1,248
    So those are basically the only 2 sizes to look for ?
  12. #27
    garrettg is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS-V
    Jan 2009
    246
    Black TD with caps
    245/45/18 conti dw
  13. #28
    Junior1's Avatar
    Jun 2008
    1,248
    Found some R888's and R1's... What's the preferred size 275/40 or 275/35 ??? BTW I haven't seen 245/40 yet
  14. #29
    tweeter81's Avatar
    Mar 2005
    Gillette, WY
    35
    1,620
    I would definitely go with 275/35r18 size for the rear (and all around if you can) because that matches the stock O.D. almost perfectly. If you do need to go with 245s in front, the 245/40r18 is the only 245 size that will match up correctly with the rear 275s.
  15. #30
    Junior1's Avatar
    Jun 2008
    1,248
    Thanks for the help tweet. Which tires of the bunch seem to be the most forgiving, ie. have some feedback before they let go, rather than just let go?
  16. Remove Advertisements
