So maybe I'll just make a DIY Heat Extractor hood
Page 1 of 5 12345 LastLast
Results 1 to 15 of 69
Like Tree4Likes
2004-2007 Cadillac CTS-V Appearance Mods Discussion, So maybe I'll just make a DIY Heat Extractor hood in Cadillac CTS-V Series Forum - 2004 - 2007; As I've gotten more and more into open tracking over the past 10 years, I've learned a bit more about ...
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,542
    As I've gotten more and more into open tracking over the past 10 years, I've learned a bit more about aerodynamics. Heat extractor vents in the hood have all sorts of benefits - reduce pressure under the hood (thereby reducing front end lift), improve airflow through the radiator, let some air out over the car rather than passing under the turbulent, non-aerodynamic underside, etc. The hood of the V looks like it wants to jump right off the car when you're blitzing down the straightaways at high speeds, so I'm sure some vents would be effective.
    So, I've been planning to vent the hood of my Subaru for a while. I've done most of my track days in the Subie and I think it would benefit from some hood vents, particular for the improved flow through the radiator. I've accumulated a variety of OEM vents off Ebay and from junkyards as I looked around for a possible solution. In the end it looks like the Subie's going to get a '10 Mustang GT500 hood vent, but that leaves me with some other vents to play with.
    In all the pics below the trailing edge of the painter's tape is about where the trailing edge of the fan shrouds is. No point in having the vents any farther forward than that.
    Here are some vents taken from a 80s/90s Trans Am GTA. As you can see in the linked picture, the larger ones were actually run 180deg opposite of what I'm looking for, so I guess they must've fed the air intake rather than acting as vents. Whatevah!
    Another option would be to put them so they're venting out to the sides. The shape of them doesn't really work out too well - they wouldn't line up with anything quite right.
    And then there are the smaller, side-facing vents. I think these would be a nice, subtle touch mounted in basically the same place they were mounted on the GTA hood. Line them up with the character lines on the hood and I think they'd look almost OEM. The down side, of course, is that they're not very big.
    An older picture with vents from a 80s turbo Lebaron:
    And the biggest, baddest vents of them all, the Lumina Z34 vents.
    On the Z34's hood they were mounted to vent to the side, kinda like the second set of pics I posted of the Trans Am vents. I could also do that on the V's hood, and it doesn't look bad, but for whatever reason I didn't take any pictures in that orientation.
    Although I don't have them with this set, as installed on the Z34 they had rain drip trays beneath them. I would have to either get the drip trays, or make my own, otherwise the engine bay would get doused in the rain. But I could just pull the drip trays off for the track.
    They line up almost perfectly - if I position the side of the vents parallel to the character line in the hood, the front edge of the vents lines up pretty well with the front of the hood. It's not perfect, but since they're set back almost 2ft I don't think it would matter.
    In the more expensive, blingier realm, there's these CF vents from Anvil Auto. I don't have a pair of those handy, so I can't show you how they would look on the V's hood. Here's a nice shot of them on a classic Camaro:
    They're about 8x12". In comparison, the Z34 louvers are about 7x20".
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    Dan_Gurney is offline Cadillac Owners Fanatic
    Automobile(s): 07 - CTS-V
    Jun 2010
    Arizona
    407
    Re: So maybe I'll just make a DIY Heat Extractor hood
    I would like the first ones better if you switched sides, then rotated them 180 degrees, so they follow the lines of the hood better.
    The small 2-vent ones look good up on the top sides of the hood as well.
    The big ones on the bottom look good, but i think they would look best higher on the hood
    soflarick's Avatar
    soflarick is offline Cadillac Owners Enthusiast
    Automobile(s): none
    Sep 2009
    Florida
    626
    The Z34s line up better than the units in the first photo. I know the OP is aware of this, but they would be most beneficial if they were placed just aft of the radiator, not further back. The drip trays are a very good idea. I would love to see a continuation of your efforts, esp final photos.
    You can't rotate the ones in the first photo, the vents would face the wrong direction.
    AAIIIC's Avatar
    Aug 2007
    6,542
    Quote Originally Posted by Dan_Gurney View Post
    I agree that they would follow the lines of the hood better that way, but the louvers would be facing the wrong way if you flip them 180. (They would want to scoop in air instead of venting air out.)
    Interesting - I would actually say the opposite. I'd like to see them moved forward a bit more. I wouldn't want to move them back much, as you then start to get into the area of the hood where air stacking up in front of the windshield creates a high(er) pressure area that would reduce the effectiveness of the vents.
    Although that's a Volvo S80 rather than a CTS-V, it's pretty representative of what a typical production sedan airflow is going to look like.
    AAIIIC's Avatar
    Aug 2007
    6,542
    Oh, and I'm not sure I'll ever really have the balls to do this. I guess if I can find a cheap-ass donor hood to cut as a test before I cut into the "real" hood? I still haven't had the guts to chop the Subaru's hood yet, and that car is a beater compared to the V.
    soflarick's Avatar
    Automobile(s): none
    Sep 2009
    Florida
    626
    Find out what a local shop would charge to integrate it into the hood and paint. There's a shop in my area that has done excellent work for me at a good price, so when I saw this thread, I thought "I'll bet they can do this and it may not cost an arm and leg".
    I've had heat extractor hoods on Mustangs and Miatas, and the performance improvement was always outstanding. Problem with them was that water would get into the engine bay and corrode things. I ran the Miata on the street with open cell foam jammed in the vents if I suspected rain. Specter's hood has drip trays. Unfortunately, it's rather expensive. If I needed to upgrade the cooling system, I'd probably put my money on their hood first. Everything under the hood runs cooler, in addition to the aero benefits you've mentioned.
    Jun 2010
    Arizona
    407
    Quote Originally Posted by soflarick View Post
    Yeah i was just commenting on looks... functionality... that is another story.
    just remember that GM put a lot of engineering into shaping things the way that they did. (not to say we can't make it better) There may be some benefits to not having a big hole in the hood for higher speed aerodynamics
    soflarick's Avatar
    Automobile(s): none
    Sep 2009
    Florida
    626
    I'm sure their engineers worked their tails off, then the bean counters pulled the carpet from under them.
    A properly executed heat extractor hood would have added cost and complexity to manufacturing the car, which would have been passed to the consumer in the price, and most drivers probably wouldn't have known the difference, so GM decided not to bother. A comparison would be that OEMs use idiot gauges for oil pressure and coolant temp rather than an actual functional gauge. Regular folk not interested in cars like it smooth and easy.
    UnsafeAtAnySpd's Avatar
    UnsafeAtAnySpd is offline Cadillac Owners Connoisseur
    Automobile(s): '04 CTS-V, '07 SRT8 Jeep, '86 Fiero
    Aug 2007
    Arlington, VA
    31
    1,647
    Don't use the TA vents. People use those on Fieros all the time and they're ugly.
    AAIIIC's Avatar
    Aug 2007
    6,542
    Highly unlikely. I can't think of any way in which the car would not see the benefits I mentioned in my first post. Obviously every car has its own aerodynamic peculiarities, but the fact that the area under the hood is at higher pressure than the air above the hood, thus generating lift on the front end, is going to be true of every sedan. Now, if the V was very light in the rear at high speeds, such that it was prone to spinning at speed, then reducing front end lift (adding more front end grip) would be a bad thing. But I don't think the V is that unstable at high speeds.
    There's a reason that the cars in every sedan-based racing series have vented hoods (assuming the rules allow it, of course).
    tweeter81's Avatar
    tweeter81 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Mar 2005
    Gillette, WY
    35
    1,620
    I really like the last pic of your car with the Z34 vents, that could look really nice if done properly. When I get my light issue figured out, I will post some pix of my SW Heat Extractor.
    As for the added aero benefits: I am really hoping for a bit more of a planted feeling from the front end on high speed road courses, or while doing a top speed interstate run.
    shadybx7's Avatar
    shadybx7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Platinum CTS V-Headers+3in pipes
    Apr 2008
    3,014
    best appearance thread in months... i like the look of the z34 vents, looking forward to seeing pics of the next step in the process..
    kirchbed's Avatar
    kirchbed is offline Cadillac Owners Fanatic
    Sep 2008
    Washington, DC
    337
    Quote Originally Posted by AAIIIC View Post
    ...There's a reason that the cars in every sedan-based racing series have vented hoods (assuming the rules allow it, of course)....
    Exactly...
    AAIIIC - think the z34 vents are right for the build. I would definitely fab up on a junker hood before you proceed with your car though. Looking forward to updates. Curious how you sourced so many different hood vents. Locally?
  16. #14
    AAIIIC's Avatar
    Aug 2007
    6,542
    Mostly sourced from ebay over the years. And I forgot another set I've got, from the '87/88 Tbird Turbo Coupe. As you can see, on the Tbird they were inlets (not sure if they actually went to anything or were just for looks), but you could easily turn them around to use as vents. The opening is about 1" deep by 5 or 6" across. No pics of those mocked up on the V, as I don't think they'd be big enough for what I want.
  17. #15
    bneal1022's Avatar
    bneal1022 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS-V, K&N, Borla, short throw w/ Holden knob, hotchkis
    May 2009
    40
    906
    I do not believe placement matters as much as the size. Given fluid dynamics.....would these not simply work like venturis? The rushing air across the top will cause a low pressure and draw air up through the vents while in motion?
  18. Remove Advertisements
