Ebay - CLEAR FOGS - Page 4
Page 4 of 16 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 ... LastLast
Results 46 to 60 of 230
Like Tree2Likes
2004-2007 Cadillac CTS-V Appearance Mods Discussion, Ebay - CLEAR FOGS in Cadillac CTS-V Series Forum - 2004 - 2007; Anywhere to buy just the lens?...
  1. #46
    agp's Avatar
    agp
    agp is offline Cadillac Owners Connoisseur
    Automobile(s): Ex-CTS owner
    Mar 2009
    SE Michigan
    1,229
    Re: Ebay - CLEAR FOGS
  2. #47
    Noisycow's Avatar
    Noisycow is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Platinum CTS-V
    Dec 2010
    Portland OR
    103
    I prefer to use HOEN H11 55w for the fogs, amber V-Leds for the above/DRL part, and 194 LEDs for the sidemarkers vs standard bulbs.
    Order the $299 fogs/sides package today.
    V-Leds for the front turns - http://www.v-leds.com/Exterior-LED/P...70676-1-2.html + 3/6 load resistors
    I'll be disabling my DRLs. Apparently the dual white/amber type don't work well with our cars so I won't go the route.
    Latest Ebay Link:
    http://cgi.ebay.com/ebaymotors/03-07...Q5fAccessories
  3. #48
    TroyFleming is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Aug 2009
    206
    If anybody has purchased these Clears and has a set of original CTS-V amber fogs/with brackets they want to sell let me know need them for a carbon fiber project.
  5. #49
    Noisycow's Avatar
    Dec 2010
    Portland OR
    103
    I bought Hoen H11 55w bulbs for my new Ebay clear fogs, but the connector/lamp assembly is different vs OEM. Bulb that comes with the clear fogs is GE H10 9145U 42W where the connector pins are spread farther apart .
    Off to look for brighter lamps that will fit.
  6. #50
    Noisycow's Avatar
    Dec 2010
    Portland OR
    103
    Going to give these a try: Nokya Arctic White 9145 Headlight Fog light bulb Stage 2
    They are very bright apparently; will adjust the fogs downward so as not to blind other drivers.
  7. #51
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,156
    Quote Originally Posted by Noisycow View Post
    Probably because it's the wrong bulb. H11 and 9145 are not the same, as you've now discovered. What led you to buy the H11 bulbs? I think it's H10 that shares the same connector as 9145, but I'd have to verify that before I actually bought H10s.
    Regardless of what brand of bulbs you buy, this page on Sylvania's website is very handy for figuring out what you need.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  8. #52
    Noisycow's Avatar
    Dec 2010
    Portland OR
    103
    I bought the Hoens when I was going to simple replace the bulbs in the stock fog housings which are different than the Ebay clear fog connectors. Now I am confused ... oh well. When they get here I'll know, the hard way.
  9. #53
    V-Guy is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 CTS-V, Raven/Ebony; Harley Fatboy; Harley Ultra-Classic
    Dec 2010
    Indy
    509
    I like the idea of clear fogs and turn signals with amber bulbs - but I don't really care for the 70s-style lenses. I think I'd like lenses that are truly clear.
  10. #54
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    Quote Originally Posted by V-Guy View Post
    The diffused lens does look a bit dated however the fog lights are pretty useless without that lens due to the way they are designed. With a clear lens you just get a scattered non directed light that distracts other drivers coming towards you.
  11. #55
    Dec 2010
    Indy
    509
    Quote Originally Posted by crankedupforit View Post
    I didn't know that - but it makes perfect sense. Thanks!
  12. #56
    cmiller is offline Cadillac Owners Member
    Automobile(s): 07 CTS-V Raven
    Aug 2010
    Madison, WI
    40
    50
    Just ordered a set with the clear side signals. Can anyone offer any suggestions on how to remove the side marker cover to replace it? I am trying to figure out what type of amber LED light to put in there and don't want to force the cover off.
  13. #57
    bneal1022's Avatar
    bneal1022 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS-V, K&N, Borla, short throw w/ Holden knob, hotchkis
    May 2009
    40
    906
    you have to remove the inner wheel wells and they unclip from inside the car nose. lots of simple work to get to. any 194 style led will work but go as low profile as possible so it fits through the side marker hole but behind the housing. do not force you must release from inside
  14. #58
    Aug 2010
    Madison, WI
    40
    50
    Thanks for the info. I was looking at these lights http://www.v-leds.com/Exterior-LED/C...00672-1-2.html. Would they work or do I need something that projects light 360 degrees like these http://www.v-leds.com/Exterior-LED/C...1014-1-2.html?
  15. #59
    bneal1022's Avatar
    May 2009
    40
    906
    actually side firing in your front markers is pointless. try these instead. front (top) is more suited given the bulb orientation in the marker light housing
    http://www.v-leds.com/Exterior-LED/C...81007-1-2.html
  16. #60
    Aug 2010
    Madison, WI
    40
    50
    ok, I was assuming that the bulb was mounted differently than it is I guess, is the inside of the housing a reflector?
  17. Remove Advertisements
