How to remove grill for painting - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Like Tree1Likes
2004-2007 Cadillac CTS-V Appearance Mods Discussion, How to remove grill for painting in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by AAIIIC There may be other, better threads to bump, but I found this one while searching. How ...
  1. #16
    shadybx7's Avatar
    shadybx7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Platinum CTS V-Headers+3in pipes
    Apr 2008
    3,014
    Re: How to remove grill for painting
    Quote Originally Posted by AAIIIC View Post
    There may be other, better threads to bump, but I found this one while searching. How does one remove the upper grille without removing the bumper? When I removed the grille to powdercoat it a few years ago, I pulled the bumper. If I can get the grille off without all that work I would much rather do it that way.
    So, what's the trick?
    skinny arms haha.. you need to get at all the clips at the bottom of the upper grill. you need to get a screw driver behind the grill to pop the bottm most GM push pin clips..
    its possible.. here is the only pic i have with the wide mouth bass look
  2. #17
    CTSV_510's Avatar
    CTSV_510 is offline Cadillac Owners Connoisseur
    Automobile(s): '06 Z06, '05 CTS-V 453rwhp/434rwtq (sold)
    Jan 2008
    West Chester, PA
    34
    4,455
    Quote Originally Posted by shadybx7 View Post
    How do you get those clips at the bottom of the top grill back in to replace the grill? I looked at them and I'm sure I could get them out, but getting them back in seems like it would be nearly impossible unless you put them in backwards (upside down). Especially the one in the middle.
  3. #18
    shadybx7's Avatar
    Apr 2008
    3,014
    Quote Originally Posted by CTSV_510 View Post
    installed a few backwards if i remember correctly but i know i didn't re-install all of them.. no negative side effects
  5. #19
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    ...yet...
  6. #20
    vcaddy06's Avatar
    vcaddy06 is offline Cadillac Owners Fanatic
    Automobile(s): '06 Black Raven CTS-V
    Sep 2009
    Palm Beach County, FL
    168
    Just to let all of you who want to paint it or have just painted the upper and lower grill and trim, I had both grills and trim painted and clear coated and now it looks like complete crap. There's paint chips all over the trim and the mesh (upper and lower). I would highly recommend not painting any of it. Hope this result helps anyone.
  7. #21
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,302
    Powdercoating is the way to go. I had mine done a couple years ago and they still look fantastic.
  8. #22
    Automobile(s): ZIP
    51,885
    Powdercoating on metal, Plasti-dip on plastic...
  9. #23
    CTSV_510's Avatar
    Jan 2008
    West Chester, PA
    34
    4,455
    I took the bumper off for this, otherwise I knew I would be breaking a bunch of clips. The bumper is really easy to remove and then its really easy to get the grills off.
    2007ThunderV and 2007ThunderV like this.
  10. #24
    wcryan is offline Cadillac Owners Connoisseur
    Automobile(s): 07 CTS-V Maggied
    Aug 2009
    Escondido, CA
    28
    1,065
    go to the plasti dip thread. That will help you
  11. #25
    2007ThunderV's Avatar
    2007ThunderV is offline Cadillac Owners Fanatic
    Automobile(s): 2007 cts v
    Jul 2011
    482
    i would just take the bumper off , i have had my bumper on and off at least half a dozen times in the last few months, only takes me about 10 min tops now.
    its only 2 bolts on each side, a crap load of platic pins. gl
    a trim tool is your friend for this task
  12. Remove Advertisements
