Results 1 to 5 of 5
    AAIIIC's Avatar
    AAIIIC is online now Cadillac Owners Connoisseur Cadillac(s) I Drive: '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    1,164
    Question Bumper brace on bottom of headlights?
    A couple weeks back when I pulled my bumper off to get the grilles powdercoated I noticed something didn't match on the two sides of the car. On the driver side, there's a flat, stout plastic brace that extends out from the bottom of the headlight about 1" or so to help hold the bumper cover up:
    The passenger side headlight didn't have that same piece:
    I know that the front end was hit prior to my owning the car, and I wouldn't be at all surprised if one (or both?) of the headlights isn't original. However, all the markings on both lights indicate that they're GM parts - same "VALEO SYLVANIA" markings in the plastic, same type of GM part number stickers on both headlights.
    Looking at the bottom of each headlight you can see how the brace is held onto the driver side headlight by 2 fasteners (I don't remember if they were pop rivets or screws):
    There's nothing on the passenger side headlight that appears broken off, nor does there appear to be any place for the same sort of fasteners to attach:
    You can clearly see the difference the brace makes in the appearance of the bumper cover. The driver side sits noticeably smoother:
    So, has anyone else noticed anything like this? Did GM change the design at some point? Maybe GM added the brace at some point to fix the wavy bumper cover, so my DS headlight is newer?
    '05 Stealth Grey CTS-V, Hyper Silver Linea Corse Venetos w/Continental ExtremeContact DWs (summer), GM Accessory wheels (winter/track), Hyperblack Rota Torques (extra/winter?), KW Variant3s, Kooks 1-3/4" long tubes w/cats, Magnaflow exhaust, UUC motor and tranny mounts, UUC shifter (not worth the trouble), MAPerformance trailing arms, Specter cradle bushings, and more to come I'm sure...
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Advertising world
    Many
    TroyFleming is offline Cadillac Owners Fanatic Cadillac(s) I Drive: CTS-V
    Aug 2009
    132
    Re: Bumper brace on bottom of headlights?
    Post the numbers on the Headlights. 2004 did not come with the brackets. If you owned this from new then I have no clue, but if purchased used, most likely previous owner had a fogged up headlight and replaced with older without bracket/or newer that has bracket. Car was in accident and went with an older headlight or went with newer headlight depending on year of car 2004 or 2005-2007 or dealer replaced one headlight under warranty.
    AAIIIC's Avatar
    Aug 2007
    1,164
    I didn't bother to write down the part numbers, and I'm not motivated enough to pull off the bumper just to read those stickers. And unfortunately I don't have the raw image files anymore, just the downsized versions I posted above. It looks like the passenger side one says PN 15278229 or 18278229, but it's a little blurry in the picture.
    I bought it used 2 years ago, and as I said in the initial post, it's definitely had some paint work done on the front end. Based on what you're saying it sounds like in the process of fixing some sort of front end damage the original 2005 headlight must've been replaced by a 2004 one. Thanks for the info on the change - that's a handy piece of info to have. If I decide to replace that passenger side light I know now what I need to look for!
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads):
    jebfrank's Avatar
    jebfrank is offline Cadillac Owners Fanatic Cadillac(s) I Drive: 98 Catera 78 Deville 05 CTS-v
    Oct 2005
    Indianapolis, IN
    30
    182
    Humm, let me know what you come up with this. My bumper has some pretty bad warpage under both lights and it looks like this brace would cure it.
    ctsv154's Avatar
    ctsv154 is offline It's a love hate thing Cadillac(s) I Drive: 04 CTS-V with a little hp persuasion device
    Oct 2007
    25
    3,706
    The new lights have the support, the old ones didn't. I have the same issue as I have had one of my lights replaced under warrenty and the other is not.
    04 Raven CTS-V / Forged and maggied LS6 / 90mm TB / 8 rib pulleys / 8" overdrive balancer with 2.7" blower pulley / LG G5X1 / Crane 1.8 gold rollers / 1 7/8 Kooks / ARP hardware throughout / Melling oil pump / Cloyes double roller / Volant CAI / Exedy Hyper Twin / Ground Control / RC51 motor mounts / UUC diff, and shifter bushings / UUC Vknob / Katech STS / Rear strut bar / Kars III
Simply register and/or login to remove these advertisements.
  • You may not post replies
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum | kia forte forum | used car savings
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
