Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V Appearance Mods
2004-2007 Cadillac CTS-V Appearance Mods Discuss all Cadillac CTS-V appearance modifications here. Spoilers, tint, wheels, tires, lighting and more.
Cadillac Forums: CCW owners look plz!
Old 03-05-08, 06:36 PM
Cadillac(s): Cadillac
View v10boost's Photo Album
Casino Cash: $4875
Hello,
I just ordered SP550 for my V and decided to go with 255 front and 295 rear in 19s. I know some of you guys used this setup and just wanted to ask if it fis ok. CCW said it fine but i just want to get first hand feed back from owners. Did you have to roll the fenders or anyther modifications to make them fit?
thanks guys
  #2 (permalink)
Old 03-05-08, 06:49 PM
Cadillac(s): 05' Stealth Gray CTS-V, UUC STS, Cags Eliminator
View keithsm2's Photo Album
Casino Cash: $4034
Re: CCW owners look plz!
I dont have them but have been looking for a straight up answer on Tires and wheels myself..
I want to keep it on 18's but would like wider in the rear and front if possible...
(not to highjack your thread....just along the same lines )
  #3 (permalink)
Old 03-05-08, 06:50 PM
Casino Cash: $4875
no problem here, this is what forums are about.
  #4 (permalink)
Old 03-05-08, 06:58 PM
LUVMY04V's Avatar
Cadillac Owners Master
Cadillac(s): 04 cadillac cts v
View LUVMY04V's Photo Album
Casino Cash: $18133
Originally Posted by v10boost View Post
Hello,
thanks guys
i have read that it would work but i also do not have them.
BTW what is the sidewall 40? 35?
Used To ..............LUV my 04 V
  #5 (permalink)
Old 03-05-08, 07:02 PM
Casino Cash: $4875
I'm not sure, probably 35.
  #6 (permalink)
Old 03-05-08, 07:09 PM
VELOSE's Avatar
Cadillac(s): CTS-V
View VELOSE's Photo Album
Casino Cash: $300
I didn't have 255 front or 295 rear on my V. With the 245f/275r, the V still looked quite nice, imo. After I lowered it, i still didn't have any problems with rubbing. I tracked this car too and didn't have any rubbing.
I know you can run the tires you've purchased with stock ride height. If you decide to lower it, you might have to do some modifications like rolling fenders and such to avoid rubbing.
http://www.cadillacforums.com/forums...ccw-sp16a.html
  #7 (permalink)
Old 03-05-08, 07:50 PM
Cadillac Owners Enthusiast
View AlmostAV's Photo Album
Casino Cash: $10390
19x10 ccw's with 285s rubbing on hard turns and dips in the road.....on eibachs
  #8 (permalink)
Old 03-05-08, 07:57 PM
Cadillac(s): '05 CTS-V
View AAIIIC's Photo Album
Casino Cash: $10355
So just to be sure we're clear, you don't know what tire sizes you're getting, we don't know what width the wheels are, and we don't know what the offsets are, but you want us to tell you if they'll fit OK?
Wheels should look badass, I'll be interested to see pics once you've got them on hand.
'05 Stealth Grey CTS-V, GM Accessory wheels w/Falken FK452s, Hyperblack Rota Torques w/Bridgestone RE-01Rs, KW Variant3s, Magnaflow exhaust, UUC shifter (not worth the trouble), Specter cradle bushings (somewhat useful), BMR pinion brace, and more to come I'm sure...
  #9 (permalink)
Old 03-05-08, 09:33 PM
tweeter81's Avatar
Cadillac(s): 2004 CTS-V
View tweeter81's Photo Album
Casino Cash: $13310
See in my sig what I am running. With my sizes (basically the size smaller than what you are proposing) I had to have a body shop roll the fenders and now I only get rubbing if an adult is sitting in the back seat of my car.
My opinion, go the size smaller (if you plan on lowering the car) and be safe. Even then, you will most likely have a very small amount of rubbing if you are lowered.
To be fair though, I had to roll the front fenders because about a week after I installed the wheel/tire combo I must have hit a bad pothole or something and the tire caught the fender and actually bent the sheet metal very slightly, so I immediately took the car into the body shop to get the fronts done. As of right now, I still have not had the rear fenders rolled, and I think that is why I still (only occasionally) get rubbing in back. So you might be OK with the bigger size if both sets of fenders are rolled, but then again maybe not.
2004 CTS-V
Mods: Lingenfelter CAI, OEM style spoiler, CCW SP600 wheels (19"x9" and 19"x10"), Toyo Proxes R888 (F: 235/35YR19 - R: 295/30YR19), Magnaflow Cat-back, UUC Shifter w/ Lindsay bushings, FG2 shocks, GC Coilover Kit (600f/650r), Hotchkis Swaybars, Custom FRCs, Kooks 1 3/4" Cermakromed LT Headers & HiFlo cats, ARP Header Studs, Granatelli 1200* Wires, NGK TR55ix Plugs, OC Autosports D&S Rotors, Hawk Pads, SS Brake Lines, 561 Wheelhop Kit, D.R.E. Dyno Tune = 351 hp/ 365 ft-lbs (corrected)
  #10 (permalink)
Old 03-05-08, 10:04 PM
View ssmith100's Photo Album
Casino Cash: $8726
They will work fine as long as you aren't lowered. That's what I have. 295's on the back will only rub on a very hard bump. I'm running a lot of positive camber too so that increases the likely hood of rubbing. My fenders aren't rolled either. I would recommend Michelin PS2's for your tires though. John can install them for you there. I should be getting a commision on these wheels. I was the first.
Shane
  #11 (permalink)
Old 03-05-08, 10:10 PM
lunarx's Avatar
Cadillac(s): 05 Mallett 427 CTS-V
View lunarx's Photo Album
Casino Cash: $6362
Let me guess,
CCW won't tell you what your offsets are?
He claims he has it all worked out?
You have nothing to worry about?
05 Mallett [M] CTS-V: 499WHP 497WTQ | 427 C5R Block | Ron Davis 2-Row Rad | [M] Oi1 Cooler | P&P LS6 Heads | FAST 78 IM | LPE CAI | SW 1-3/4" Headars | RT Hi Flow Cats | B&B 3" Exhaust | RPS Street-Twin Clutch | McLeod Billet Slave Cyl | [M] ST Shifter | RPM Trans Level-V Build | MN6 Geer Ratio Conv | Cryo Treated Diff | GM T2 Diff Cooler | [M] Anti Wheel Hop Kit | FG2 Shocks | SS Brake Limes | Slotted Cryo Rotars | [M] Modified Front Spindles | 275-35-19 PS2 F&R | [M] 19x9 Billet Whels F&R |
  #12 (permalink)
Old 03-05-08, 11:00 PM
Casino Cash: $10355
Originally Posted by ssmith100 View Post
I'm running a lot of positive camber too ...
Ummm... Why?
  #13 (permalink)
Old 03-05-08, 11:19 PM
Casino Cash: $8726
AAIIIC,
I didn't like how the 295's bowed in at the top since there so much wider than stock on the ten inch wheel. Increasing the camber "straightened" everything out. Hope that makes since.
Shane
  #14 (permalink)
Old 03-06-08, 07:56 AM
Cadillac(s): 04 CTS-V
View kgoch's Photo Album
Casino Cash: $3245
I have 19x10 in the rear. Lowering the car 1" causes the wheel to rub the trailing arm on bump. The shop is working on a fix now. The rear suspension must toe-in on bump causing the wheel to come in contact with the trailing arm. At stock ride height there were no problems.
  #15 (permalink)
Old 03-06-08, 06:26 PM
MSOsr's Avatar
Cadillac(s): 2007 SRX and 2005 CTS-V (both black)
View MSOsr's Photo Album
Casino Cash: $14335
Would 245/40/19 and 275/35/19 work fine with 8.5" wide front wheels and 10" rear wheels?
Mike (considering the move to 19s)
Tags: , , ,
ccw, owners, plz
Censor is OFF
